RE: Re: OT: Sorry, just a quick one: Need separate syringes for > different colours?
2006-03-29 by G Guhan Gunaratnam
Thanks a lot Barbara.  But could you tell me what a needle inflator is?  Is
this just the normal 1.5" needle I'd normally be putting into the syringe?
Thanks again
On 3/28/06 4:40 PM, "DigitalBlackandWhiteThePrint@yahoogroups.com"
<DigitalBlackandWhiteThePrint@yahoogroups.com> wrote:
> Message: 1
>    Date: Tue, 28 Mar 2006 08:35:16 -0800
>    From: "Barbara Woolner" <bfwoolner@...>
> Subject: RE: Re: OT: Sorry, just a quick one: Need separate syringes for
> different colours?
> I've solved the syringe problem by following the advice of some smart cookie
> on this forum by using his method, ie: drilling a hole in the top of my 4 oz
> refill bottles, gluing in a needle inflator and inserting a straight pin in
> the hole when not in use.  Works like a charm, just insert the needle
> inflator in the cart, tip the bottle and fill.  No washing or changing
> syringes required.  When the bottle is empty I just screw the top with the
> inflator needle onto the new refill bottle.
> Sorry, I can't remember who first wrote about this technique, but whoever
> you are, THANKS!
> Barbara Woolner
