Scanning Pyro Negs?
Scanning Pyro Negs?
2006-03-27 by scott_now_coming
Anyone here scanning Pyro stained negative with any success?
Any info or links will be appreciated.
Scott
Re: Scanning Pyro Negs?
2006-03-27 by mxgo95747
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "scott_now_coming"
> Thanks,
> Scott
 I tried scanning some 35 mm negatives on my Canon FS4000 and Epson 4870.  The
negatives seem to have a lot of noise, come out very light (even with a good histogram),
and  they seem to have an opaque "film" on the negatives.  However, when I work them in
Photoshop CS2, the noise is not seen in my 8 by 10 and 11 by 14 glossy prints.   But, my
B&W prints are rather high contrast;  a lot of black areas with Zone 3 detail.
The "but" in my response is that my scanner is not calibrated and I used Vuescan 8.3.32
and 8.08 to see if it made a difference.  Also, I had the same problem with Iford XP2.
I tried regular B&W film "Iford 50" and it does not have the same appearance.  If you get an
answers, please post them.
Martin
2006-03-27 by lulalake_1999
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mxgo95747"
<mxgo95747@...> wrote:
> --- In
> > Thanks,
> > Scott
4870.  The
when I work them in
Zone 3 detail.
used Vuescan 8.3.32
> Martin
Martin,
I am using W2D2, Wimberley's Pyro version, FP4+, MF, and have not had
those issues. I scan with an Epson 4870 as a 24 bit color neg then
convert to B&W in CS. I also use Vuescan.
Here's an example:
http://tinyurl.com/r5jc5
Pardon the size but squashing it down just doesn't work.
Jules
2006-03-28 by mxgo95747
-> I am using W2D2, Wimberley's Pyro version, FP4+, MF, and have not had
> Here's an example:
> Jules
 Also used FP4 (and FP5), except that I scanned in 16 bit B&W negative.  I will try scanning as
24 bit color negatives.
Martin
2006-03-28 by scott_now_coming
Hi Martin,
Thanks for the reply.
Wading through the results of a GOOGLE search, I saw where a guy
scanned some Pyro negs. I think he scanned them in RGB and used the
green channel for printing.
He was really excited about the results. And the article was from
2003. So, I'm encouraged.
I have a couple of 120 rolls of Delta 3200 in my freezer. I'm going
to find a development time for this film and my Pyro and give it a
shot.
Also, I hear the chromogenic films scan real nicely.
(I haven't shot film since I went digital 5 yrs ago. I have my Rollei
loaded and ready to go. Going to shoot some film tomorrow. Now, I'm
just waiting for the Epson V-750 to be released.)
Scott
4870.  The
when I work them in
Zone 3 detail.
used Vuescan 8.3.32
> Martin
Jules,
Are you using only one "channel" to print with?
Or are you using the file as RGB to print with?
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lulalake_1999"
> <mxgo95747@> wrote:
> > --- In
> > > Thanks,
> > > Scott
Epson
> 4870.  The
However,
> when I work them in
> Zone 3 detail.
I
> used Vuescan 8.3.32
> > Martin
> Martin,
had
> Here's an example:
> Jules
2006-03-28 by lulalake_1999
> Jules,
> Thanks,
> Scott
Hi Scott,
I do all my processing (not really all that much on a pyro neg)as a B&W
scanned in as RGB, then when I go to print, I convert the image to a
20% dot gain grayscale. I use QTR and a 2200 for smaller work and farm
it out for larger prints.
Jules
> Jules
Jules, thanks for the input.  Using the 24 bit color negative setting, in Vuescan, for "Pyro"
processed B&W film and converting them to B&W in PhotoShop did the trick.  I have a lab in
Sacramento, California do the "pyro" processing.  They only do B&W work.
Martin
> --- In
a B&W
to a
farm
> > Jules
work.
> Martin
Thanks for the tip Martin. Could you post the URL for tha lab so I
can stop stinking up the house with pyro developing?
Thanks again
Jules
2006-03-28 by jurajlipscher
Hi Jules & Martin
1. There is a fairly extensive article on scanning pyro negatives and
selectively using different color channels in the magazine 'Ag' No.
26. Here is their webpage with the possibility to order back numbers:
http://www.ag-photo.co.uk/
2. I have been working with PMK for the last 15 years and am presently
also using Pyrocat HD. I scan both kinds of negatives either with
EPSON 4990/Vue Scan or IMACON 646 and have beautiful results with both
developers and both scanners.
On and off I am poring over the following question which is directly
pertinent to this list:
Enlarging pyro negs (PMK and/or Pyrocat) on multigrade silver paper
gives you the advantage of the yellow/brown stain selectively holding
back the hard blue light of the enlarger so that the highlights be
selectively filtered down by the stain and thus giving better
differentiation in the highlights. This has been described in depth by
 Gordon Hutchings (inventor of PMK) and also by Sandy King (inventor
of Pyrocat).
Now what I would like to work out is how to achieve similiar increase
of differentiation of highlights in scanned pyro negatives. This would
have to entail scanning the pyro negs in colour and then simulating
the selective filtering by intelligent use of the channel mixer or
some such in Photoshop.
Has anyone any ideas in this direction or does anyone know someone
with such ideas? ;-)
best regards
Juraj
> a B&W
> to a
> farm
> > > Jules
> work.
> > Martin
> Thanks again
> Jules
--. Could you post the URL for tha lab so I
> Thanks again
> Jules
http://www.coxblackandwhitelab.com
Since I live about half an hour away, I always spend a few minutes talking them and usually
get a lot of help from them.
Martin
Re: [Digital BW] Re: Scanning Pyro Negs?
2006-03-28 by Louis de Stoutz
Hi Juraj,
I'm working along the same line.
Alas, every time I decide to concentrate on a specific film, it tends to
disappear from the market...
Can you tell me what format/film combinations you prefer?
Best regards,
Louis
2006-03-29 by Brian Ellis
"I used pyro on a couple of films a while back and while I was
impressed with the lack of grain in areas of continuous tone (sky
etc.) I found the grain quite exagerated in other areas compared to
some other developers"
I performed extensive testing comparing pyro to D76 several years ago. My
basic procedure was to make duplicate negatives of various scenes, develop
one in pyro (PMK) and one in D76 1-1 using lford HP5+ film, then making
prints from both. I found no advantage  to the pyro prints in the sense that
identical prints could be made from either set of negatives. I concluded
that even if there happens to be some scene somewhere that could be
photographed and better processed in pyro, for the vast majority of scenes
pyro just wasn't worth screwing around with.
Sent: Wednesday, March 29, 2006 3:15 AM
Subject: [Digital BW] Re: Scanning Pyro Negs?
some other developers.
I used FP 4 and Pan F in 35mm and have a Minolta Scan Dual III.  The
Pan F was fairly grainless but was very high contrast so highlights
didn't hold a great deal of detail.  I didn't use an alkaline fixer
which I understand makes a difference to the stain.  Perhaps I should
have another go with an alkaline fix and reduce my dev time...  (I'm
afraid I've been chasing silver bullets for a while and never settle
long enough on any technique to really work it out properly.  When
will I learn?)
One idea I've recently had was simulating the effects of Pyro in
Photoshop.
Roughly speakly:
1)  Develop and scan your film as normal - I like to apply a slight
USM with no threshold to make the grain less mushy, but your scanner
might be better than this.
2)  Use grain removal software (eg Neat Image / Noise Ninja) to
produce a reduced grain version of the original.
3)  Create a photoshop file with two layers:  the full grain and the
smooth.  Probably put the grainy version on the bottom.
4)  Create a layer mask for the top layer using the technique
described for capture sharpening here:
http://www.creativepro.com/story/feature/20357-2.html.  Blend the two
images by eg setting the opacity of the top layer to 50%.
I've inconclusively played around with this but wonder if anyone else
has some similar techniques up their sleeve.
Some further thoughts:
1)  You could do this in reverse using digital capture (another silver
bullet):  your initial capture becomes your grain-free layer and you
can create a layer with added noise as your grain layer.
2)  Speculatively:  you could use a pyro negative to emphasise this
effect if you could somehow separate the grain and the mask into
layers.  You would probably need a really good stain to stand any
chance of getting this to work.
Chris
they are often being updated.
page.
them short.
membership without notice.
the membership.
Yahoo! Groups Links
2006-03-29 by Clayton Price
Hi All -
I'm a little late to this discussion but perhaps can add a little to
what Juraj has written.
Many years ago I was mixing Pyro formula from scratch but found that
PMK worked at least as well,
and came partially pre-mixed.  I used it for all my fine art negatives
- 4X5, but mostly 120 and
35mm.  I love the staining of the shadow areas, which allows for much
better control of the highlights
without burning out shadows. Additionally, there's something in the
formula that slows the silver particles
from migrating into adjacent areas with less density.  I don't remember
the technical explanation, but the
net result is sharper delineation.  Depending on the subject and the
light, there can be a dramatic
improvement in prints.
So 5 or 6 years ago, I started scanning some of those negatives, and
the results were terrific. Because the
stain is greenish. brownish, yellowish :-), my best results have been
scanning in RGB and as Jurj has mentioned, converting
to grayscale via channel mixing in Photo Shop. My logic for this is
that the green channel controls much of
the shadow detail you want to show through (since most of the stain is
in shadow areas).  Also, one
would have to scan the negative as if it were a transparency - i.e.:
the scan comes up as a negative.
Only after working on it in channel mixer should it be inverted to
positive. That will take some experimenting
because it's so difficult to make tonal judgments looking at a negative
image, but IMO it's worth the trouble.
As far as grain is concerned - I think there may be a little more grain
with PMK developers, but personally, I like
grain most of the time and never thought of it as a problem.
On Mar 28, 2006, at 4:40 PM,
> Message: 2
>    Date: Tue, 28 Mar 2006 16:34:56 -0000
>    From: "jurajlipscher" <juraj@...>
> Subject: Re: Scanning Pyro Negs?
> Hi Jules & Martin
> of Pyrocat).
> best regards
> Juraj
2006-03-29 by Chris Ellis
will I learn?)
Photoshop.
Roughly speakly:
Chris
2006-03-29 by jurajlipscher
Hallo Louis
In the old days I used TriX with PMK in 5x7" but since about 5 years
I am almost exclusively using 120 TMax 100 with either PMK or
Pyrocat HD in 6x6 and 6x12. TMY 400 in these developers is a tiny
bit too grainy for my taste so I try to avoid it.
Up till now TMax films are still available without problems here in
Switzerland.
best regards
Juraj
> Hi Juraj,
tends to
> Best regards,
> Louis
2006-03-29 by hogarth@snappydsl.net
> My basic procedure was to make duplicate negatives of various scenes,
> develop one in pyro (PMK) and one in D76 1-1 using lford HP5+ film,
> then making prints from both. I found no advantage  to the pyro prints
> in the sense that identical prints could be made from either set of
> negatives. I concluded that even if there happens to be some scene
> somewhere that could be photographed and better processed in pyro, for
> the vast majority of scenes pyro just wasn't worth screwing around with.
I came to the same conclusion -- that pyro just isn't worth it. Not by
doing the experiments myself, but by hearing results from you and a
bunch of others who had done the experiments.
I ended up using XTOL at 1:3 with Tri-X. I compared it extensively to
HC-110 and exchanged some email the inventors of XTOL and Steve Anchell.
My conclusion was that you didn't really start to see differences
between film developers in prints until you got up to around 15x
enlargements. Since I'm shooting 5x4, I never make prints with anything
like that much enlargement.
I ended up with XTOL because it gives a nice clean sharp image with
decent grain (not too big, nicely formed), and nice even tonality. That,
and it gives me 2/3 stop more real film speed, and it's way more
environmentally friendly than the others, especially the pyro family.
And I should note that Tri-X with XTOL is really easy to scan well. It
scans well on a cheap flatbed like an old Epson 2450, and it scan really
well on my drum scanner. And because the negative isn't colored like a
pyro negative is, I can easily scan it with just the green channel which
saves me a bunch of disk space and workflow time.
So the closest I got to pyro was to buy the nitrile gloves. People who
use pyro swear by it though, so clearly YMMV.
Bruce Watson
2006-03-29 by scott_now_coming
I just loaded some Delta 3200 in my Rollei. I'll shoot it in the next
couple of days and the develope it in Pyro TEA.
Unfortunately, I won't have the new Epson scanner for a while as
Epson isn't yet accepting "pre-orders" for the V-750. :>(
Anyone using Pyro TEA?
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Clayton Price
<clay@...> wrote:
> Hi All -
to
that
negatives
much
remember
and
been
is
i.e.:
negative
grain
> > Message: 2
> > Hi Jules & Martin
and
No.
numbers:
presently
both
directly
paper
holding
depth by
(inventor
> > of Pyrocat).
increase
would
simulating
> > best regards
> > Juraj
Chris,
The fixer you used washed away the "strining", so you didn't get the
effects of the pyro develpoer.
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Chris Ellis"
should
> will I learn?)
> Photoshop.
> Roughly speakly:
two
else
silver
> Chris
One of the main advantages of using Pyro TEA is you only have to buy
it about once every 10 years or so. Just top it off with "fresh"
developer.
When it gets to the consistancy of glue, make a new batch.
Mine is 6 years old and still going strong. Not ever close to "glue"!
Scott
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Brian Ellis"
ago. My
develop
making
sense that
concluded
scenes
> From: "Chris Ellis" <christian.ellis@...>
should
> will I learn?)
> Photoshop.
> Roughly speakly:
two
else
silver
> Chris
resources as
wish to
this same
> page.
to keep
> them short.
flames.
B&W
removed from
> the membership.
and
Owner and
section:
PRINT
AND
LIABLE TO YOU
EXEMPLARY
THE  "OWNER" AND
OF THE
INABILITY
ACCESS TO OR
CONDUCT OF ANY
OTHER
