How is ink limitation performed ?
2006-03-30 by Olivier
I've review the all group messages without finding the reply.
Given a printing resolution, a fixed dot size (to make it simple), I
guess the only way ink is limited is at the dithering level (e.g. less
dots printed). Is that correct ?
Olivier
Re: [Digital BW] How is ink limitation performed ?
2006-03-30 by Ernst Dinkla
> Olivier
Yes, depends where it falls. Could be less dots, distribution
of the dots, smaller droplet size, a lighter ink in the
inkset. In that order I think but there are many different
media around that will not all cope with only dot number
changes (and that's limited too if you want to keep some
smoothness). In RIPs you can change the point where darker
inks are replaced by lighter inks and Epson must have that
choice too when making the paper settings for the driver.
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
> Ernst
Very clear, Ernst as usual. In fact, it's in the 95-100% range I was
wondering relating it to Dmax.
Again at a given dot size (forgetting VDS here), ink set... I'm
assuming dot gain will be the ultimate factor in ink limtiation,
meaning on one hand the paper on the other hand the dpi resolution.
Say paper is given again, I'm left with dpi and a direct relation to
larger dpi-smaller fixed dots (at 2880). I've seen you repeatedly
mentionning smaller dots lead to higher relative dot gain (unless
wrong) : so where do we stand in terms of reaching higher Dmax. We're
better off with small drop or larger ones ?
View like this I'd go for higher dpi and smaller dots. Basically, I'm
still stuck with what best dpi reso to use despite hundreds of posts
on the issue and Roy's mentionning 1440 is very fine vs 2880 makes me
wonder, because the 95-100% will probably use larger dots and put
together with your saying smaller increase dot gain and density make
me thing Dmax can/should be increased with smaller dots.
I'm sure I've got something wrong here...
Olivier
I have made a step wedge for QTR with some checks on bleeding.
Usually on good papers the Dmax stops increasing before the
bleeding gets ugly. Looks like the chemists have an idea how
to keep the print characteristics of the ink under control.
You can bet that Epson engineers fix the relation between the
different dotsizes on an average dotgain. So not a 1:2:4
relation on dot area but a 1:2:4 relation on actual density
measured in tests on several papers. You run into a different
problem with smaller dots, the placing of the smaller dots
gets far more irregular than they are with larger dots. The
differences between smaller droplet contents is higher than
between larger droplets contents. The pro printers almost
always had larger droplets than the desktop models and Epson
mentioned that consistency of droplet size was more important.
So you either choose for a more precise dot placement but
slightly rougher screen or you go for a finer dot with more
fluctuation in the density and in detail. The Dmax will not be
better at 100% when there's no white left. The control of the
95-100% range isn't better with smaller dots either.
There's a good piece of PR on the new Canon FINE heads here:
http://consumer.usa.canon.com/pixma/press/FINE_TG_0909.pdf
Propaganda but I think they mention some important issues.
At the highest resolution the number of droplet sizes get
less. The evolution we have seen  with increased resolution is
a smaller minimum droplet size, more droplet sizes, more grey
inks. For a good reason as just making droplets smaller isn't
working.
I'm sure it is more complicated than we both think it is.
Ernst
           Ernst Dinkla
(         unvollendet         )
Yes, I experienced +/- the same : except EEM (and I don't know why),
all VFA, USFA, HPR and so-called fine art papers "hold" ink pretty
well. In fact, I'd have expected a little bleeding in total black
areas (99-100) would have provided total coverage while retaining
Dmax, hence my question.
Which turns for us, users, uncontrollable. But that a fair technical
proposal from Epson, since I'd assume the driver then turns to be a
nice piece of complexity.
Ok, you have a point. With the new x800 generation, do you feel
(finger in the air) that 1)this physical precision has improved, 2)
the new K3 resin-coated formulation plays a big and different role in
dot gain, overprint effects...What makes me think this is that the
OEM calibration Colorbase can only be used in 2880dpi whichever media
type.
I'm sorry I can't get the translation of a "droplet content". I'm
French.
That partly replies the above, but you might refer to the x600
printers (?).
I've read through it, but will properly study it cool headed.
> working.
I'd have thought that all those elements precisely call for smaller
drops. Basically, if the purpose is smoothness, maximum shades
reproduction (grey values), detailed prints and media coverage,...
one has to combined a precisely built head (your link) to be capable
of as small as possible dots (for smoothness and dotless prints)
dithered by a first-class driver (for the best trade off between
value/detail) with a variable density ink set (for maximum shades
reproduction) with ink formulation that combines both right pigment
load and eventually low dot gain.
I've seen K3 lacking a L-LLK, and somehow lacking (a bit) Dmax, so
I'm at a stage where I wonder whether on principle highest dpi
setting for smallest drop possible would eventually better the print
at all levels without generating issues like dot registration, drop
size... I also count on a reasonnably long overlap and some
significant extra K blackboost to smooth the print yet give good
Dmax.
Does that all make sense or not worth trying ?
Olivier
> type.
> French.
1/ another grey ink added does wonders, no I don't think that
precision became much better, speed was more important, there
must a trade off between the two  2/ Yes, I think the 9800
range could be better for gloss printing in the first place
and isn't as good for matte as the 9600 range was. At least we
start to think that over here. The 9800 is also harder to
adapt to third party inks. However with a  RIP it must be
possible.
Pardon, I'm Dutch so it will not be proper English either.
Combien d'encre par une goutellete (had to look up that word
:-) 3.5 picoliter could be 3 or 4 picoliter.
> printers (?).
To all the pro printers in time compared to the
consumer/desktop models of the same generation.
>> working.
I think you see it as a theoretical concept. I guess the Epson
heads have their limitations as well. So is the hardware and
software that drives them. The Canon pages I gave the link too
may be exaggerating the limitations but they are revealing
some basic requirements for further developments. For all the
three inkjet head technologies. It is also interesting that
Canon goes for a 16 bit driver with this technology. This
could go two ways, at last there is the hardware that can
represent the 16 bit smoothness, color accuracy and/or they
need the 16 bit to get it all controlled.
> Dmax.
For one reason or another it has always been hard to develop a
continuous tone printing technology that has a high Dmax +
consistency in output + sharp detail. That was so with
Collotype, Screenless Offset, Conventional Rotogravure,
Woodbury Type to add an odd one as the last. For process
control you see that they don't push the pure concept but add
better controllable technology and make it a hybrid process
like the semi halftone in modern rotogravure shows. I think
that inkjet right now is very close to the ideal that the
other processes tried to achieve. With a hybrid of all tone
forming elements known in printing as one only couldn't
achieve that goal. Your infinite small droplets has it
limitations as described. Best example that they tried before
is the Iris printer with its continues one size droplet stream
(though then with larger droplets). It had wonderful smooth
gradations, good color but lacked sharp detail and the printer
needed a lot of maintenance for consistent work. It has been
replaced by the Epson head technology. The successor of the
last could be Canon's new heads. It can pump a lot of small
droplets to the right place, so they are trying again.
Ernst
           Ernst Dinkla
(         unvollendet         )
> possible.
1/ yes, which also comes down to how many dilutions is enough.
Apparently, 3 can achieve the goal. A L-LLK is missing, so a more
precise partitionning and dithering is probably needed. 2/ Just K3
alone + QTR might get me there e.g. glossy prints. If not I'll wait
for Glossy Piezotone inks.
Regarding droplet content (excellent French BTW and we're not hat far
apart) you mean say a 20pl has a higher probability of being close to
20 than a 4 to be 4 (for instance 19.5 vs 3.5)?
> The successor of the last could be Canon's new heads. It can pump a
>lot of small droplets to the right place, so they are trying again.
I really need to dig into that pdf that I printed and Canon site...
Olivier
