Paper color change Mohab Entrada Natural?
2006-04-01 by Mr_Misty_44
I was just looking over some of my prints done on Entrada Natural and
notice that the paper seems to be yellowing. I also noticed some
uneven yellowing in at least one print. Has anyone else encountered
this? Very disturbing to say the least
John H
Re: Paper color change Mohab Entrada Natural?
2006-04-11 by pekozip93
fyi..Ive email moab on this, and another issue Ive heard...
apparently (and cannot verify) but the yellow inks supposedly fade
much more rapidly than do the other inks (which dont fade much at all)
leaving a potential bluish cast eventually..
This all takes me much be surprise, Im hoping this may well be an
old paper stock issue that has since been rectified.
how old was the stock you printed on and when did you print the images
you mention below?
Frank
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Mr_Misty_44"
> John H
Re: [Digital BW] Re: Paper color change Mohab Entrada Natural?
2006-04-11 by hogarth@snappydsl.net
It shouldn't. There are a number of issues with using color inks to
print B&W images. One of these issues is differential fading causing
color shifts as some colors fade faster then others. Search the archives
and you'll find discussions of this and numerous other topics about
using color inks to print B&W images.
While the current crop of inks is pretty good about this, it's not
immune. Most prints framed under a glazing will do OK. If your prints
are just laying around without protection, then can pick up
contamination from air and surfaces they touch which will vastly hasten
their deterioration. Laying a print on top of a newspaper overnight can
cause it to yellow within days for example. Storing unprotected prints
in a wooden drawer can have a similar effect. I have no idea what this
would do to the inks, but it can't be good.
Bruce Watson
2006-04-12 by CDTobie@aol.com
Ink fading is not a paper issue, unless a particular papers cause inks to
fade differently than other papers of that type in class, which is not true of
Entrada. Differential ink fading is a fact if life, but yellowing indicates Cyan
ink fading, not anything happening with the yellow ink. I see no note of what
inks you are using, but this is most common with dye inks.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
In a message dated 4/11/06 10:50:11 AM, photographer93@... writes:
> you mention below?
> Frank
2006-04-13 by hogarth@snappydsl.net
> to fade differently than other papers of that type in class, which is
> not true of Entrada. Differential ink fading is a fact if life, but
> yellowing indicates Cyan ink fading, not anything happening with the
> yellow ink. I see no note of what inks you are using, but this is most
> C. David Tobie
I respectfully disagree. Ink and substrate/coating form a system, all
parts effecting to a greater or lesser degree the other parts. The
coating on a paper can have an effect on ink longevity. Particularly the
porosity of the coating. This is particularly true of dye inks, but
should also be true of pigments inks if to a lesser degree. The theory
is that the coating can protect the ink from atmospheric pollution. The
type of binder used in the coating can also effect ink longevity, as
does the effective use of a mordant, again more for dyes than for
pigments, but something one can not discount out of hand. I'm sure there
are other factors as well, but I haven't seen any papers discussing
them. Not that I'm spending a lot of time looking.
Bruce Watson
2006-04-13 by CDTobie@aol.com
In a message dated 4/12/06 9:06:10 PM, hogarth@... writes:
The question was on a far more basic level: the user was assuming color shift
was being caused by the paper changing tone, when its almost surely the inks
changing tone. Yes, the paper and coatings effect ink shift, but thats on a
much subtler level than assuming its the paper that's yellowing.
C. David Tobie
Datacolor Inc.
CDTobie@...
www.colorvision.com
