Re: [Digital BW] Digest Number 3850
2006-04-02 by MGochnauer
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, aromanocpa@...
> wrote:
>> ... why do you use a 220 for color? and if so, what inks for
> archival purposes. Does the quality of a 4x6 through a 8.x10 hold up
> to the more expensive printers?
As Mike replied, the Epson inks are dye based. I have substituted MIS
PRO inks... the same ones I use in my 2200.
Using MIS PRO inks in every cartridge, the R220 lacks only the light
black used in the 2200 printer. I cannot believe that this could not
make a difference in some circumstances, but for ordinary printing
for "friends, family and 'fridge" the results are excellent, and
would be as archival as MIS pigments can be. Unless I remember when I
printed many things around my house I ordinarily can't tell whether I
used the R220 or 2200. But then, I like photographic images, so I
tend to look at the pictures rather than the papers, or inks, or
grain pattern, or dots, or whatever else reveals technique and
technology. Suffice it to say, I *never* look at an 8x10 from the
R220 and think, "Hmmm. I like that! I'll have to print it with the
*good* printer."
MIS didn't have chips for the R220 colors the last time I looked, so
I have been using the original Epson chips on refillable MIS
cartridges. The chips reset nicely with the "universal" chip resetter
from MIS (and others, too, I assume).
And yes, I use Eboni or PhotoBlack according to the printing surface.
I use the same Epson R220 "black" chip for both of them. Prints fine.
No clogs so far, either.
I have made my own colour profiles for the combination of R220, MIS
PRO inks and the papers I use.
I do quite a bit of Black Only printing with the R220. Works nicely
for T-Max 400 35mm scans.
Myron
