R220 Shutdown.
R220 Shutdown.
2006-04-05 by robert49brake
It's time to go back to work and I'll will be needing to shut down my
printer quite often, typically 10 days to a month at a time.  (I'm
using MIS UT-R2)  Any suggestions for putting it to sleep.  I remember
seeing something on the subject, maybe in this forum, but I've been
unable to find it again.  Any suggestions?  On a similar note any
recommendations for switching between warm and neutral cartridges and a
good way to make sure the heads are cleared of the old ink.  Thanks.
Re: R220 Shutdown.
2006-04-06 by mimimike43
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "robert49brake"
my
remember
and a
Message #75045
Date: Mon Mar 6, 2006  5:51 pm
Subject: RE: [Digital BW] Clogging lowdown? R200/220, HP 8450
pr_roark
 Offline
 Send Email
 Invite to Yahoo! 360ยบ
Eamon,
> I'm just about to dip my toe into digital B&W printing, and I'm
> leaning towards an Epson R200 or R220 with the MIS Ultratone inks.
Go with the R220 if feasible.  There were a few useful changes.
> But I frequently go several (or many) weeks without doing any
> printing...
To avoid problems, just have a set of carts with cleaning fluid in
them.
Buying empty carts and bulk cleaning fluid is probably the easiest
way to go
in the long run.  Put in the cleaning fluid carts when you're going
to be
gone for a few weeks.  Perhaps do a cleaning cycle, but that may not
even be
necessary.  Rinse off the outlets of the ink carts, tape the outlets,
and
they'll be ready to go when you get back and re-install them.
In general my experience with the R220 is that it's a very easy to
maintain
printer -- no serious clogs yet, and I do a lot of ink changing and
experimenting.
