<paul.roark@...> wrote:
> > What are the percentages of gray ink, in each respective
cartridge
> > of the MIS UT-R2 inksets that go in the R220. Both the Neutral set
> > and the Warm set. Is there a difference between gray ink density,
> > and ink percentage?
> I don't think in terms of ink percentages, because it implies some
absolute
> standard reference point. Percentage of what? Measuring the
carbon content
> or density?
> MIS occasionally uses a percentage number on its inks, but they
should not
> be taken literally. They are only used to indicate relative
density, and
> the percentages used are not directly related to any content or
measure.
> The UT R2 midtone inks come in 2 densities and 2 tones (hues). The
neutral
> C & M inks are the same ink. The neutral LC, LM, and Y are the
same ink.
> Ditto for the warm inks. The densities are the same as most of the
other
> recent inksets I've worked on. The carbon (warm) set is, in fact,
the same
> as the UT2 and UT7 (and UT 3D) carbon. These are standard
densities that
> I've found to match the Epson driver assumptions and crossovers.
All Epson
> hextone printers are surprisingly alike.
> > Would you be kind enough to explain what the chemistry is that
makes
> > one set Neutral and one set Warm.
> The warm is pure carbon.
> The neutral has cyan and R800 clone blue pigments added to cool it
down to
> close to neutral. How neutral it is depends on the paper. I try
not to
> have it go green, however. As such on most papers it has a very
slight
> magenta or "selenium" tone. Lab a* between 0 and 1 is my ideal
range for
> neutral a midtone with Lab b* = 0.
> > You suggest that by replacing the yellow positioned cartridge in
> > Neutral set, with that of a respective Warm cartridge, it will
warm
> > the Neutral prints. Are there other combinations that you would
> > recommend juggling?
> It's really a matter of personal taste and paper choice. You can
also mix
> (physically pour them together) the warm and neutral inks to any
> intermediate hue. You can also use cool in the light and warm in
the dark
> or vice versa for a split tone affect.
> Have fun; experiment.
> Paul
> www.PaulRoark.com
Thanks much for you very detailed and direct answer.
Mike
