new r220 / mis ut-r2 - printer doesn't recognize cartridge?
2006-04-11 by brianechapman
Hey, I've got a problem and hope someone can help.
I just received my MIS UT-R2 inks and R220 printer.  I followed the
installation instructions but when I closed the ink cover after
installing the R2 inks - nothing happened.  The power light contined
flashing and the red ink light was solid.
It seems to me the most likely thing is that the printer doesn't
recognize the cartridges.  I haven't yet tried it with the epson
cartridges because I wanted to sell them...
Anyone got any ideas?
Brian
Re: [Digital BW] new r220 / mis ut-r2 - printer doesn't recognize cartridge?
2006-04-11 by Tom Baker
Turn the printer off, and then back on.  If you get the message that a cart is not installed, it is not making correct contact with the chip.  A gentle cleaning of the chip made some difference. Or, remove and reinsert the cart.
  If you get the message that it doesn't recognize the cart type, it will probably print anyway.
  I had similar problems.   Removing and reseating the carts helped in some cases.  In the end, it all works fine.
  Tom Baker
Brian
- By posting on this forum you agree to abide by the group rules and guidelines, and to abide by the actions and decisions of the group Owner and Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE PRINT YAHOO GROUP.
  SPONSORED LINKS
        Digital wedding photography   Learn digital photography   Digital photography college     Digital photography   Digital photography web site   Digital photography course
  YAHOO! GROUPS LINKS
    Visit your group "DigitalBlackandWhiteThePrint" on the web.
The problem is the Yellow cartridge (I sacraficed the Epson inks...) -
the printer operates correctly with the MIS cartridges in all
positions except for Yellow.
If it's most likely the chip I can swap out the chip on the epson
cartridge with the MIS cartridge...it doesn't look that
difficult...has anyone done this?  Is there any other reason why the
cartridge wouldn't work?
Thanks, Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Tom Baker
>   Tom Baker
> Brian
this same page.
to keep them short.
Owner and Moderators. See "Group Topic, Rules and Guidelines" in the
Files section:
PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LOSSES (EVEN IF THE  "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
2006-04-11 by mimimike43
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "brianechapman"
> Thanks, Brian
I just installed the MIS set a couple of weeks ago in my new 220.  And
yes,  I also set the printer up with the MIS B&W cartridges.
Everything went smoothly.
Perhaps you might want to call MIS.  Maybe they will swap your yellow
cartridge.  Switching the chip does sound like an idea,  have you done
this before?
Good Luck
Mike
Firstly, the BO option works and as expected produces excellent
results - thanks to everyone who has published so much helpful
info!!!
Mike, I'll give MIS a call this morning - from what I've read on
their support site, etc, the problem is almost certainly the chip.
I'll give a couple other things a try (shim the cartridge) to see if
I can get the chip to work otherwise I'll probably try replacing it.
Thanks!
Brian
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "mimimike43"
And
yellow
done
> this before?
> Good Luck
> Mike
