Good RIP for the Epson 2200??
2006-04-14 by lulalake_1999
Hi Folks,
I use QTR regularly for B&W but need to print color from time to time.
Can anyone recommend a good RIP for the 2200?
I've been looking at the Wasach RIP. Anyone use this one?
Thanks
Jules
Re: Good RIP for the Epson 2200??
2006-04-14 by Tyler Boley
Unless you have some very specific unusual needs, good profiles and
Epson driver really do take care of most things with a printer that size.
I'm afraid I'm unfamiliar with the Wasach, only StudioPrint. Even with
it, I'd wonder about investing in that software for a desktop printer.
Tyler
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "lulalake_1999"
<lulalake_1999@...> wrote:
> Hi Folks,
> Thanks
> Jules
2006-04-14 by Louis Dina
I'd agree with Tyler.  I own ImagePrint and have tried ColorBurst,
StudioPrint and a few others with my 2200.  Most RIPs either do not
support the 2200, or do so grudgingly, since it is not
a "professional" series printer.  Apparently, some of the features
are not easily addressable by a RIP, or so some of the RIP
manufacturers claim.  Besides, the Epson driver with a good custom
profile does a superb job on most papers.  There may be a few papers
that need more precise ink limiting and linearization, but they
should be few.
I recommend a custom RGB profile with the Epson driver.  It does a
better job than ImagePrint (with or without a custom profile), and
besides, ImagePrint is very expensive for what you are getting.  Save
your money for some new toys!
Lou
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Tyler Boley"
size.
with
printer.
> Tyler
> <lulalake_1999@> wrote:
> > Hi Folks,
time.
> > Thanks
> > Jules
Re: [Digital BW] Good RIP for the Epson 2200??
2006-04-15 by Ernst Dinkla
lulalake_1999 wrote:
> Hi Folks,
> Thanks
> Jules
I have the Wastach SoftRip 4.5  but hardly use it. Only on
canvas and for odd experiments. Sometimes you can do things
better that way but it often is more work.
Qimage + the Epson driver is just easier and in some aspects
better. If you need to process Postscript files then use Adobe
software for rasterisation.
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
2006-04-15 by Johnny Eades
My $.02 worth would suggest getting a package like PrintFix Pro to
creae printer profiles, so that if and when you acquire another
printer you could do it for that one also. In addition to color
profiles, the software can also be used with the Spectro qlong with
Qtr to make ink/paper curves for BW.
Your friend in photography,
Johnny Eades
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Louis Dina"
> should be few.
> Lou
> size.
> with
> printer.
> > Tyler
> > > Hi Folks,
> time.
> > > Thanks
> > > Jules
2006-04-15 by lulalake_1999
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
> > Hi Folks,
time.
> > Thanks
> > Jules
> Ernst
Hi Ernst,
Yeah, I do print a lot on canvas but Qimage looks real good. Thanks
for the tip.
Jules
2006-04-16 by Nick H. Nugent
I have used Wasatch SoftRIP for almost a year now but only on my HP
Designjet 30 which is the smallest HP printer they support. I
purchased it so I can use more media on the HP that Epson can support
rather easily.
Wasatch can produce amazing results but the learning curve can be
steep.  Since my printer profiling solution is an RGB only Gretag i1
Photo, Wasatch definitely came to the rescue when I tried to use some
of my favorite Epson media on the HP.
With Wasatch I get significantly better results than even HP's own
paper/ink combination which is already pretty amazing. This I didn't
realize after I "successfully" made a profile via Wasatch and placed
the prints side by side.
Wasatch's power is in its separation rules engine which allows you to
perform very sophisticated ink limitting. But it was this rules engine
that took me a long time to learn.
Will Wasatch work with the Epson 2200? I don't know. Will I recommend
Wasatch? I'm hesitant as I know it has a VERY steep learning curve.
But armed with Wasatch I know I'm getting the kind of output that
otherwise would be impossible.
--nick
> time to time. Can anyone recommend a good RIP for the
> 2200? I've been looking at the Wasach RIP. Anyone use this
> one?
2006-04-16 by Greg
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent"
<nghin@...> wrote:
Well, what I learned about the Wasatch softrip kept me from buying
it. When I contacted them, they said it could not change the point
where the light ink mixes with the full ink, and that you could not
chage how much light ink was used to mix with the full ink. And also
that you could not take a 6 (or more) ink printer, and change the
configuration to make something like a multi grey plus CMY inkset.
They said it had something to do with the way the dither was
designed. What this means is that you are limited to inks that offer
a similar performance to the OEM inks for that printer.
This was of course the official statement from the manufacturer, so
there might be hacks that can be performed to make it different.
Unfortunately, there are few choices for a RIP for the 2200, and the
few that there are do not offer great flexibility. You can try the
RIP from iproofsystems and see if it does what you need.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
> from buying it. When I contacted them, they said it could
> not change the point where the light ink mixes with the
> full ink, and that you could not chage how much light ink
> was used to mix with the full ink. And also that you could
> inkset. They said it had something to do with the way the
> dither was designed. What this means is that you are
> limited to inks that offer a similar performance to the
All correct. I did ask them something about why they treat
my 6-ink printer like a 4-ink printer and I think I got
the same answer. But at that time my concern was more
about color printing than black and white so I went for
it anyway.
But is there a full RIP out there that works like QTR?
For color I think Wasatch works great if one knows how to
use it.
Out of curiosity I took a look at the PowerRIP at iproofsystems and
it looks like PowerRIP X or 2000 may fit the bill at a much lower
price.
--nick
Re: [Digital BW] Re: Good RIP for the Epson 2200??
2006-04-16 by Ernst Dinkla
> it anyway.
> use it.
> price.
> --nick
Greg, Nick,
The transfer  points for the LC>C and LM>M and on the 9600 etc
LK>K can be shifted, that has been available before I got the
Wasatch SoftRip 5 years ago. The amount of light ink where it
should switch to the full ink could be based on the
linearisation curve of the C,M,K channels + the extra
correction curves, but that is a trial and error system.
Wasatch very much expects a harmonic inkset. Strange enough it
could have been added to the separation rules engine where
there are other tools to correct mismatches in the inkset
(like the CMY shift possible at the bottom of the separation
rules page).
The main limitation has been that it is very much a 4 channel
CMYK RIP for the printers that WasatchInc considers CMYK or
CcMmYK or CcMmYK(kk). So linearisation is done over the 4
channels which could mean 2 or 3 inks are linearised  in one
channel, Kkk for example, For CMYK(O)R(G)B printers etc they
have separate drivers with linearisation per channel but you
can't drive an Epson  that got CMYKOG inks instead of CcMmYK
with it. Nor Quad inks though I was able to get a 9000 running
UT inks with the Wasatch SoftRip and some weird thinking about
ink positions, greyscale files disguised as CMYK, correction
curves and linearisation curves. I was happy though when QTR
became available.
I have asked WasatchInc to look for some additions to drive
quad inks several years ago and put that request again when I
upgraded to version 4.5 (the one that got the separation rules
engine + the 3d profile viewer). They are not interested in
odd inksets for CMYKetc printers. I also believe that they do
not see photography as their core market. All the developments
have been towards sign, textile, prepress film for silkscreen
printing, data transfer through the internet, etc. To be
honest I do not understand that, a much larger market is in
photography and few additions would put good B&W printing on
the menu too. That said the Epson K3 models should make it
more easy to achieve that with the RIP as it has at least the
Kkk linearisation.
My guess is that with many RIPs you will see similar
limitations. There's a strong believe in the use of good
profiling to get neutral prints, in their view good enough for
B&W printing. Along with that all greyscale files will go
through the K channel so become BO prints. When the K3
printers were announced I asked on the Colorsync list whether
there would be an extra possibility added to the RIPs to send
a greyscale file through the Kkk lines and add some toning for
hue or neutrality. Like the Epson K3 driver has. It was
totally ignored or I got the "you want good profiling" replies.
Ernst
           Ernst Dinkla
(         unvollendet         )
2006-04-16 by Greg
Ernst, as usual, thank you. Now Nick, if you step up to a larger
Ultrachrome printer, then you get a few more options. Postershop can
be configured with multiple gray inks to make a 4kCMY machine (or at
least the sales person assures me that they can.) I could never get
the demo working properly, so I was never able to try it for even
normal inks. Also the Evolution RIP can do the same, and it should be
able to do a 3KCMY with the 9/9500 soon, I need to ask them about
that again before my year or service expires. And StudioPrint can do
the same. But for the 2200, there really isn't that much out there.
Most people can't see the value of putting a $500+ RIP on a printer
that small, so they limit the R&D needed to the larger market.
Stepping up to a 4000 opens many options.
2006-04-16 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Nick H. Nugent" <nghin@...>
wrote:
snip...
My understanding is that someone with the dedication and talent of Roy, but with a dogged
interest in color, could put an interface on top of Gutenprint that would do most things many
of us want.
Obviously linearizations, limiting, light ink crossovers, etc. can be controlled in this thing. It
just needs to be bent to our will.
Even if it's not icc aware, profile conversions could be handled in the Adobe print controls, or
with other tools like Qimage.
The B&W community benifited mightily because some some obsessive and knowledgeable
B&W individual took it upon himself to tackle the problem.
This is like most issues, there's not enough money in it I suspect.
In fact, I suspect QTR was a bigger challenge than CMYK would be, or CMYKxx...?
Tyler
2006-04-16 by Greg
> of us want.
iproofsystems did, and the Evolution is also (probably) built on it.
That and OPM for the layout features, and add in little CMS for the
color handling. Maybe need a few more tools from icc.org for the
color handling. Makes it all sound kind of easy doesn't it?
