Re: REMOVABLE PLUG FOR SEALING FILL HOLE ON SPONGELESS CARTS
2006-04-14 by Reinald S. Nielsen
For several years, on carts for Canon i860 and i950 printers, I have drilled a #36 hole, run a 6-32 tap through it, and installed a 1/8 inch Allen head set screw to fill the hole. When run in to be flush with the cart surface, a small piece of masking tap assures an air-tight seal. After acquiring an Epson 2200 for black and white printing, I purchased UT-7 inks and the ARC-2200-EC-SET of transparent carts from MIS for refilling. There are no sealing plugs for the carts (which do have sponges). The initial part of the fill hole is slightly smaller than a #22 drill, which for some unknown purpose, necks to a smaller diameter. Enlarging the entire hole with a #22 drill permits tapping it for a 10-32 screw; the hole is long enough that a quarter-inch Allen head screw is just accommodated when run in flush. As with the dye-based Canon carts, a small piece of masking tape assures a tight seal. The sponge in the 2200 carts assures that plastic chips that might arise in drilling and tapping do not get to the output orifice. In the several 2200 carts that I have equipped with a set screw, I have looked carefully, but been unable to see any loose material in the tank. When the tap is backed out, it seems to carry all the material (cuttings, chips, what-have-you) created while tapping the hole. My experience suggests that this means for sealing cartridge fill holes will be satisfactory on spongeless cartridges. Reinald in Eastern Maine
