Re: [Digital BW] Re: 1800 Ink sources
2006-05-07 by CDTobie@aol.com
In a message dated 5/7/06 10:04:02 AM, ar@... writes:
> A standard issue with all new Epson inkjets is that the first set of
> cartridges don't last as long as subsequent sets, because the printer
> has to prime/fill the ink tubes between cartridges and heads. I don't
> know whether Epson have improved the situation recently.
The only improvement would come from shortening/narrowing the tubes involved
in bulk feed. Thats not likely to happen. But the user in question cites the
R1800 which has no bulk feed; the carts sit directly on the print heads, and
initial install waste is limited to the tiny amount used to fill the heads,
and that passed through in ensuring that the heads are primed and running
properly. Not in the same category as the wideformat Epsons with their bulk feed
systems. But then, the R1800 carts are tiny, so the loss is somewhat magnified by
that.
C. David Tobie
Product Technology Manager
ColorVision Business Division
DataColor Inc.
CDTobie@...
www.colorvision.com
