UT-3D Readme file posted
2006-05-11 by Paul Roark
I've put a draft UT-3D Readme pdf up at http://home1.gte.net/res09aij/UT-3D_Readme.pdf Let me know if there are any problems with this pdf approach. In profiling glossy papers for UT-3D on the 220, I've found most can use either the Kirkland or CraneSR curve - which, for the best ramps, should then be linearized and stuffed inside an ICC using Roy's Create ICC-RGB program. Oddly, the PermaJet Fibre Gloss did not work well with the Crane Silver Rag profile. I'll be sure the Innova version has good profiles as quickly as possible. I'll be adding printers as time permits. I might even add the k3 family - needs to be tested. Paul www.PaulRoark.com <http://www.paulroark.com/> [Non-text portions of this message have been removed]
