couple of tips
2006-05-16 by Tyler Boley
I believe it's been mentioned, but the following upsize method has been working extremely well here. This assumes you need to get UP to 360dpi at print size. Res up to 720dpi at final print size using bicubic smoother. Very carefully apply some USM, for example 1 at 100 or so, barely visible on display. Res down to print size at 360dpi using bicubic sharper. With large 16 bit scans you'll have big intermediate file sizes, but it'll pass... Obvioulsy the concept can be applied to other sizes and dpi's as well. Just OVER upsize with smoother, then downsize to desired with sharper. The USM is subjective, I don't like much if any. Another extremely useful task made possible by Roy's single channel profiler- I have years of files that were optimized for a now antiquated system of creating quads that was not as device linearizable as today's options. At some point before bagging that system I had printed and measured a step wedge from it. I was able to make an icc profile with Roy's app using those measurements. Now, I can open those old files, assign that profile, and convert to whatever may be necessary to print on a comteporary system. I've successfully matched new PiezoTone prints made with StudioPrint and a 9600 with old 3000 manually separated quads printed with the old PressReady RIP. Color management and Roy come though again. Here's a lesson, perhaps a text file of your current output system, and/or it's profile, should be made and saved indefinitely. Tyler
