profile / curves question
2006-06-02 by esharamaki
I am confused about "profiles" and "curves." I currently use neutral (no tones) B&W inkset. If I have profiled my printer/paper/ink combination, why would I need a curve? Thanks, Earl
2006-06-02 by Paul Roark
> I am confused about "profiles" and "curves." I currently use neutral > (no tones) B&W inkset. If I have profiled my printer/paper/ink > combination, why would I need a curve? You may not need a curve. It's just one way to "profile" the inkset. With a monotone inkset the main goal is to get an even distribution of print densities that visually match what you see on the monitor. Although the newer inksets I've worked with tend to print reasonably well with no curves as long as the Epson driver settings are as specified, most papers print slightly differently. So, to get the same relative density (and tone where applicable) distribution across different paper types, and to achieve a better match to the monitor, I usually have different curves for different papers. Lately I've been putting these curves into ICCs, using Roy's "Create ICC-RGB" program. However, many using the Epson 220 and UT-R2 inkset, for example, find that the printer with no curve or ICC prints about the same as when one is used. Hope this helps. Paul www.PaulRoark.com
I understand a little better now. So by using the create ICC program, you're using a curve to create a profile that you would use the same way as a profile that you've created with your colorimeter? Or I'm still confused why not just use the colorimeter? Would it be that you've generated a profile to get linearity and screen matching, then add curve to adjust warmer to cooler depending on the inkset? Thanks, Earl --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Paul Roark" <paul.roark@...> wrote: > > > I am confused about "profiles" and "curves." I currently use neutral > > (no tones) B&W inkset. If I have profiled my printer/paper/ink > > combination, why would I need a curve? > > You may not need a curve. It's just one way to "profile" the inkset. With > a monotone inkset the main goal is to get an even distribution of print > densities that visually match what you see on the monitor. > > Although the newer inksets I've worked with tend to print reasonably well > with no curves as long as the Epson driver settings are as specified, most > papers print slightly differently. So, to get the same relative density > (and tone where applicable) distribution across different paper types, and > to achieve a better match to the monitor, I usually have different curves > for different papers. Lately I've been putting these curves into ICCs, > using Roy's "Create ICC-RGB" program. However, many using the Epson 220 and > UT-R2 inkset, for example, find that the printer with no curve or ICC prints
> about the same as when one is used. > > Hope this helps. > > Paul > www.PaulRoark.com >
