Sihl Iridium " RIP " -informal RC paper yellowing test
2006-06-17 by Steven Karafyllakis
Some may remember a few months back I expressed interest in a paper
called Sihl Iridium Satin. It is very nice material for an RC paper,
but the biggest drawback (until now) was unavailabilty in sheets.
That discouraged any real interest by list members, and its just as
well. I finally got around to doing an informal south-window
yellowing test, and the results were not good. But I put up some
other papers that have also been mentioned on this forum lately, and
one that hasn't, and I can at least suggest a viable new candidate
for those needing a luster/satin RC paper for commercial printing.
The papers I put up were: Sihl Iridium satin, Magiclee Lustre
Photobase, Inkpress RC Lustre, Ilford Soft Gloss (yeah I know, it's
glossy not lustre) and Oriental Graphica lustre RC. As control and
comparison I also put up Photo rag, William Turner, and Epson
enhanced matte. The enhanced Matte went up 3 days after the rest, it
was a bit of an afterthought.
I left them up for only 12 days before I checked them, and after
that short a period this is what I saw:
The enhanced matte (after only 9 days!) yelloewd the most, enough
that no control print comparison was needed to see the shift. No
surprise there.
Next in order of visible change was the Magiclee Photobase, Sihl
Iridium, and the Inkpress Lustre. The Oriental Graphica survived the
best of the lustre papers, on a par with the Ilford Soft gloss.
There may be a measurable yellow shift in those two, but since I
don't have a spectro, I can't verify.
There was no visible shift in either the Photo Rag or the Willie
Turner.
That's the bad news. The good new is that the Oriental Graphica is a
fairly attractive paper (for an RC) prints well in color, takes the
K3 & K4 inks well (but not the older UC inks) has good Dmax (anyone
care to measure it for the group?) and is available in both rolls
and sheets up to 13 x 19. Guess I'll give it a whirl.
Steve Karafyllakis
Re: Sihl Iridium " RIP " -informal RC paper yellowing test
2006-06-17 by Shilesh Jani
Steve,
Send them to me for Dmax measurements. You already have my address. I
acnnot measure color shifts, just Dmax.
Shilesh
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
paper,
and
it
> surprise there.
> Turner.
a
> Steve Karafyllakis
2006-06-17 by Andre
> surprise there.
Steve,
Can you tell if there was loss of density in the image as well with
this paper ?
TIA,
André
2006-06-17 by Greg
> (anyone care to measure it for the group?)
> Steve Karafyllakis
Are you testing color or B/W performance? CMYK RIP or no RIP (Epson
driver)? I have something I need to make a cable for and check first,
and if you felt like doing the test again with a different target.
You're in the US, correct?
I'm thinking a simple 135 patch RGB profile target (or maybe 343
patches if I can get the print small enough). Maybe a grayscale target
for those with only grayscale inks, but I would need to look into that
too. Two prints would need to be made, one exposed to light, and one
sealed away from air in the dark (to keep it from being exposed to
gases). If it works correctly I have an automated measuring device,
and that device uses very small targets, so it would be a small print
probably around 4x6 size or smaller.
2006-06-19 by Steven Karafyllakis
I am using the MIS k4 inks (photo K and both LK and LLK in an R1800)
with the R1800 MIS Pro blue and cyan for neutralizing) I saw no
signs of fading with any of the papers, but after only 12 days I
would expect to have to measure, which I'm not equipped to do. But
fade wasn't the point-I wanted to know if there would be
unnacceptably rapid yellowing of the paper base color.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Andre"
enough
> > surprise there.
> Steve,
> this paper ?
> TIA,
> André
Greg;
As I mentioned in the previous reply, I wasn't really testing either
color or B&W. However, if you'd like to do so, at this point I still
have some of the Iridium I could send you, and also the Oriental
Graphica lustre. Yes, I'm in the US, if you're interested send a
mail address, I'll send you a few sheets
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
> > Steve Karafyllakis
first,
target
that
one
print
2006-07-04 by tzinzunzan2006
A few weeks ago I received a sample roll of Sihl Iridium Satin. I've
been very impressed with the surface -- just enough gloss to enhance
the image without distracting reflections, and the the same goes for
its texture. I'd like to continue using the paper, so what you report
concerns me. However, 1) if the the yellowing is only noticeable
through comparison with "fresh" sheets, 2) it stops yellowing at that
point, and 3)there is no significant/noticeable fading, then this
paper may be good for my purposes. After all, doesn't traditional
fiber paper with OBAs yellow to some extent also? At any rate, thanks
for the information. I look forward to reading any fade test results.
Chris Hargens
> surprise there.
> Turner.
> Steve Karafyllakis
Chris Hargens
--- In DigitalBlackandWhiteThePrint@...m, "Steven
> surprise there.
> Turner.
> Steve Karafyllakis
2006-07-05 by Steven Karafyllakis
Hi Chris;
I still like the paper too; now that I finally have a densitometer
I'll put some pieces out for a fade test. Frankly, I hadn't
considered that the yellowing might stop, but if it is being caused
by OBAs burning off, its possible.
Steve Karafyllakis
http://www.stevekphoto.com
--- In
DigitalBlackandWhiteThePrint@yahoogroups.com, "tzinzunzan2006"
I've
enhance
for
report
that
thanks
results.
> Chris Hargens
paper
paper,
sheets.
as
and
candidate
printing.
it's
and
rest, it
enough
> > surprise there.
> > Turner.
is a
(anyone
rolls
> > Steve Karafyllakis
2006-07-06 by Greg
> Hi Chris;
> Steve Karafyllakis
If you feel like doing a color test, let me know and I'll make a very
small chart to use.
