MIS Pro vs MIS K4
MIS Pro vs MIS K4
2006-06-21 by Keith R.
Actually, the MIS forums will be down until mid July. As for the Pro
vs K4, I believe that the you are right about some of the colors being
the same and I think that they are the PK and LK. But unlike the MIS
Pro, which uses PK, MK(Ebony) and LK, the K4 uses LK, LLK(a lighter
light black), and EITHER PK or MK(Ebony). But not both PK and MK. The
2400, and X800, printers(the K3 printers)utilize 3 different blacks,
but not the same 3 as the printers that use the MIS Pro. With the K3
printers, you can't print glossy and matte without changing out the PK
or the MK. With the 2400, this is easier(and less expensive) than the
X800 printers, as there isn't as great amount of ink lost in the
change over. That being said, I have had my 4800 running for a little
over a week, and all I can say is WOW! I am still using the inks that
came with the printer, but when I first got it I looked into the MIS
K4 inks, asked all kinds of questions at MIS about the differences
with Epson. One difference (if I remember correctly)is that the MIS K4
doesn't have the micro encapsulation as the Epson K3. I've only made
one B&W using the ABW, but was very pleased with what I got. I'm
waiting on some paper that I just ordered, then I plan to fire up the
PrintFixPro and really set this printer up. I've been reading about
QTR, and hope to utilize it along with the PFP to get better results
with this printer when doing B&W.
KeithR
RE: [Digital BW] MIS Pro vs MIS K4
2006-06-21 by Terry Ritz
Now I'm getting very confused. I've been looking into MIS Pro and MIS K4 for
my Epson 2200. I've read a few posts in my search that say the MIS Pro will
not address bronzing, but that the K4 inks (like Epson's K3) does.
Can anyone confirm how well the MIS Pro inks address bronzing on gloss
paper?
Terry.
On Behalf Of Keith R.
> the Pro vs K4, I believe that the you are right about some of
> the colors being the same and I think that they are the PK
> and LK.
2006-06-21 by Paul Roark
The bronzing problem was very significantly helped - virtually eliminated on
many papers - by the new base MIS uses in its pigment inks.  This new base
should be in all of the MIS pigment inks.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Terry
Ritz
Sent: Tuesday, June 20, 2006 9:56 PM
Subject: RE: [Digital BW] MIS Pro vs MIS K4
paper?
Terry.
> and LK.
Re: [Digital BW] MIS Pro vs MIS K4
I do not and have not owned a 2200 printer, but from what I read, it
is a 7 ink printer and uses the epson UC inks(5 colors and 2 blacks).
The MIS Pro was designed to be used in this,and I assume other,"like"
printers. The MIS K4 inks, are supposed to be equivalent to the epson
K3 inks(5 colors and 3 black inks). Supposedly, it is the inclusion
of the 3rd black ink(a light light black)that has helped with the
bronzing. It has helped with better B&W on glossy material. As I
stated, I don't have the 2200, but unless it has the slot for the 3rd
black ink, I don't know how you can get it to work, short of using a
rip, and even then, your not able to use all 3 black inks.
As to make up of the MIS Pro and MIS K4, I did find out that SOME of
the inks are the same, and that the MIS inks do not have the micro
encapsulation technology that the epson inks have. I specifically
asked the forum admin(Marine) this and those were his replies, when I
asked in late march and early april. I had just gottem a 4800 and
having use MIS in the past with my 1280, I wanted to know what
comparisons there were between the epson K3 and the MIS K4.
KeithR
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Terry Ritz"
MIS K4 for
Pro will
gloss
> paper?
> Thanks,
> Terry.
> > and LK.
