Re: [Digital BW] Re: new 1280 print borders unequal
2006-07-03 by davidbrinson@adelphia.net
Ed, I'll check the pulldown.... At present, I run Elements 3.0.  Photoshop, soon.
Thanks, Dave
---- edrudolpho <erudolph@...> wrote:
> Hi Dave.... if printing from Photoshop, in Page Setup, on the "Format
> for" pulldown, did you select your printer type or leave it at "Any
> Printer?"  Leaving the pulldown at Any Printer seems to give
> uncentered results.
> Ed
> --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Dave Brinson"
> <davidbrinson@...> wrote:
> > Hello,  I just received and set up my 1280 which I will be using for
> > B&W but decided to run a few test prints with the color inks first.
> > The color is nice but when testing on 4x6 paper (landscape setting),
> > the printed image is not centered:  the image size to be printed was
> > 4x6; the paper size, 4x6; with or without the "borders" box checked,
> > they all are the same:  lead edge, 6mm border; bottom edge, 2mm
> > border; trailing edge, 3mm border; top edge, no border, hence, printed
> > image size, 3 7/8  x 5 5/8, +/-.  I did print the same 4x6 image on
> > 8.5x11 and it did print a 4x6 image but not perfectly centered when I
> > had it set up to do so.  Any clues?  I hope this printer didn't
> > receive too many bumps with UPS on trhe way here.  Any help greatly
> > appreciated.
2006-07-04 by davidbrinson@adelphia.net
Thanks Keith,   I'll give it a try.
Dave
---- "Keith R." <kjrslr@...> wrote:
> Hi there!
> Came across this awhile back when I had a 1280 and PS7:
> http://www.computer-darkroom.com/ps7_page/page_layout.htm
> This should help at least get you close to "why" your prints don't get
> centered, and can show you a way to fix it. It uses Mac OSX, but I run
> windoze and the info applied as well.
> KeithR
> printed
> I
> > appreciated.
Dave
> Hi there!
> KeithR
> printed
> I
> > appreciated.
2006-07-04 by jimcongleton
Dave,
    I ran into this problem with my 1280 when I upgraded to OS 10.4/PS Elements 4, but
was able to get equal margins all around by setting up custom page sizes with a 0.25
margin on all sides. Although the computer-darkroom.com article says that OS 10 doesn't
support custom pages sizes, that is apparently no longer true.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, <davidbrinson@...> wrote:
> Dave
> > Hi there!
> > KeithR
> > printed
> > I
> > > appreciated.
Thanks for the input, Jim.  I'll give it a try when I get my computer up and running again.  It went kaput last night.
Dave
---- jimcongleton <jconglet@...> wrote:
> Dave,
> > Dave
> > > Hi there!
> > > KeithR
> > > printed
> > > I
> > > > appreciated.
RE: [Digital BW] Re: new 1280 print borders unequal
2006-07-04 by John Ketcham
I get to a centering choice by page setup > printer properties > paper and
then printable > centered.
John Ketcham
<http://geo.yahoo.com/serv?s=97359714&grpId=3702311&grpspId=1600019182&msgId
=78278&stime=1152019162>
2006-07-06 by davidbrinson@adelphia.net
Thanks John,  .....as soon as I get my computer up and running,  I'll five ut a try.
Dave
> John Ketcham
