Ren Wax on Silver Rag printed on a 2400
2006-07-07 by TK Thompson
Ok, I did the coatings test on Silver Rag similiar to what I did on
Innova F type that I reported earlier.  The best looking section of
the Silver Rag print was coated with Premier Print Shield with no
wax!  THe second best looking to my eye was the plain print with no
coating - it did have evidence of gloss differential but did have
luminous shadow detail.  The Premier Print Shield only section had
zero gloss differential and slightly more "richness"
and "luminosity" to the shadow detail.  There didn't seem to be much
difference in the highlights. The third best looking was the wax on
top of Print Shield - the fourth was the waxed only print with no
spray.  Again the ClearJet Semigloss FA spray gave a veiled look to
the print whether waxed on not.
Some caveats:
These were pretty subjective tests judged with only my eyes and a
friend - we agreed on the results.  All were done on the same
printer using the same K3 set of ink cartridges with the PK black.
The differences between 1st, 2nd, and 3rd places are very small,
like barely noticable.  The same image was used for both tests, just
printed on the different papers using the same printer setting for
both.  The prints were evaluated on my desktop with a drafting light
that had both a florescent and incadesent bulbs operating. Maybe
using daylight would give different results.  I only had the
ClearJet Semigloss FA spray - they make a lot of other types of
sprays that may work better.  The semigloss kind of kills the
richness of both of the papers tested.
What I learned:
For me, I will use Premier Print Shield spray with Silver Rag prints
and will wax Innova F Type Gloss Ultra Smooth prints with Rennesance
Wax.  I will use both papers, the innova has a white base whereas
the silver rag has more of a cream color base.  Both papers give
about the same tonal range with my printing scheme. Both make very
lovely images. I think the gloss differential issue is overblown for
framed work - you can't see it when framed behind museum glass.  It
may be visable when looking at prints held in the hand - it takes a
pretty acute viewing angle to see it on the uncoated section of the
print.
This is what worked for me with my setup and my eyes for evaluation -
 I advise anyone interested to do their own testing to arrive at
their own results.
TK
Re: Ren Wax on Silver Rag printed on a 2400
2006-07-08 by john dean
Yea, the Premier Art adds to the dmax of glossy media and does a good
job of smoothing the gloss difference issues. It does a specially good
job with Silver Rag. Just wear a charcoal fileterd mask if you want to
keep your brain cells.
john
> Some caveats:
> What I learned:
> print.
> their own results.
> Cheers,
> TK
RE: [Digital BW] Ren Wax on Silver Rag printed on a 2400
2006-07-12 by Paul Roark
> I did the coatings test on Silver Rag similar to what I did on
>wax! The second best looking to my eye was the plain print with no
>coating ...
One reason I'm tentatively enthused by the paper is that it should allow me
to avoid sprays, etc.  With MIS inks I find almost no difference between the
sprayed and unsprayed Silver Rag.  The surface appears to be sufficiently
abrasion & fingerprint resistant that normal handling will not cause
problems.
