When to swap ink carts that aren't yet empty
2006-08-23 by bvalente
Hi all,
I am looking for the common wisdom on replacing ink cartridges on my
2400 that aren't yet empty. I just received my set of UT-3D inks (all
cartriges) and I am anxious to try them out since I do mostly B&W.
However, the current Epson k3 cartriges are still about 1/3-1/2 full.
Do I
a) suck it up an use up the Epson cartridges until they are empty and
then switch them
b) Swap them out now, an store the epson ones (in a plastic bag or
whatever) and use them later.
Thanks for any guidance
Brian
Re: When to swap ink carts that aren't yet empty
2006-08-23 by Clayton Jones
Hello Brian,
One advantage of b) is that if you ever have to send it for repair or
return, or swap it in an upgrade plan, you can put those carts back in
and not have to go buy a set.
Paul Roark recommends using water to clean off any ink residue on the
bottom of the poppet valve before storing to ensure it doesn't dry and
clog.
Clayton
Hi Clayton
Thanks for the tip. Now, onto the UT-3D!
Brian
or
in
and
> clog.
> Regards,
> Clayton
