Underwhelmed with r220
2006-08-27 by chriskjezp
I've been making prints with an r220 and MIS R2 variable tone inkset (as suggested by one of Clayton's articles) using several different methods: 1) Black only, 2) using driver sliders as described by Clayton, 3) using Paul's ICC profiles and 4) a combination of Paul's ICC profiles to control density/tone and the Epson sliders to control temperature. In all cases I am somewhat satisfied but mostly underwhelmed. From what I had read here, I expected a significant improvement in print quality from my Canon MP800 with this r220. However, this morning I printed out a few test files on my r220 and MP800, and there is very, very little difference. In fact, in some cases, my MP800 (which is a fairly average Canon printer) performed better than the r220. This file is one example (http://static.flickr.com/62/202370145_620711ee7a_o.jpg). On my r220, the transition between solid black and lighter grey in the upper right corner is very abrubt. It almost looks like I took a felt pen and colored it in. On the MP800, however, it prints smoothly and appears basically as it does on my screen. A more detailed example which I would expect the r220 to really beat the MP800 is this: http://static.flickr.com/73/162049980_3126c60674_o.jpg. But again, I see little difference between the MP800 and r220. I keep telling myself there must be something I'm doing wrong, but I've gone over everything several times and all of the settings are correct. At this point it seems the only reasonable conclusion is that the MP800 is a much better printer than I thought, or the r220 with MIS inks is not as great as I hoped. Now I'm wishing I would have got the 2200 or stretched and bought the r2400. Do you have any thoughts? Thanks, Chris
