Re: [Digital BW] IS it possible to get decent Black and White prints with the HP 90?
2006-09-07 by CDTobie@aol.com
In a message dated 9/7/06 1:22:57 PM, sjahjah@... writes: > I am about to give up, I tried several papers, even bought the > outrageously expensive Imageprint v6...and, while it improves matters a > bit, does not provide decent b&w! > The HP DesignJet 30/90/130 printers use colored dye inks, and are mostly used on gloss/luster media (as it fades, and fades differentially, on matte media causing color casts in B&W prints). The driver blends grays and light grays from Cyan, Magenta, and Yellow inks. So any slight variation in neutrality will show as a color cast, or a series of them. Moving from one light source to another will also cause significant change in the tone of B&W prints made this way. ImagePrint doesn't have a lot of good choices for working with this printer: there are no gray inks, so it either uses a "black ink only, with bits of color to tint it neutral" strategy, which will cause rather weak, grainy images, or it uses a scheme about like the RGB driver, and gains some smoothness and richness, but at the cost of stable neutrality. The next generation of HP DesignJet printers should offer pigment inks and other improvements, though what specs have been published so far indicate that there will be only one, not two, levels of gray ink, so Epson and Canon models are still likely to be ahead in printing of B&W images. We'll know more at Photokina. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com [Non-text portions of this message have been removed]
