solution found: can now print postcard stock on R220 - keeping fingers crossed
2006-09-08 by paulmwhiting
Thanks to a member here who e-mailed me a suggestion to join the Epson Printer group and get help from Arthur Entlich. He most definitely helped. Apparently Avery postcard stock leaves some of its coating on the rollers. The rollers get glazed, making it harder to grab the next sheet, and a vicious circle begins. He suggested spraying some isopropryl alcohol on a sheet of watercolor paper and running that through (one side up, then the other). Haven't tried that yet, but plan to go over to the art store and pick some of that paper up soon. Arthur was a tremendous help, told me I hadn't really damaged the paper sensor (since other paper was ok). I also broke open my package of Epson Enhanced Matte which seemed as thick as postcard stock and that also worked... probably doesn't have that coating. Arthur suggested I write Avery, that he's seen this issue before and they need to have some customer feedback. In the meantime I called Epson again and the tech suggested downloading a more up to date driver and this seems to have done the trick! I told Arthur I'd let folks here know how it all turned out. So, keeping fingers crossed. Between his excellent maintenance tip and the new driver, I think I'm out of the woods.
