Gutenprint
Gutenprint
2006-09-12 by crosslink770
Hi All,
I'm new to digital printing and am researching options before buying
my first printer.
I think I would be interested in trying black-only printing along the
lines of what Clayton Jones describes.
http://www.cjcom.net/articles/digiprn3b.htm
As a Linux user, I would be very interested in doing this with
Gutenprint. I've read the documentation, but as a newbie it's hard to
tell whether Gutenprint allows this type of control. Any other options
that might be useful for *nix computing systems?
Re: [Digital BW] Gutenprint
2006-09-12 by Mark Savoia
Why fight it? Why not use a standard operating system, Windows or Mac?
Mark
On Sep 12, 2006, at 7:28 AM, crosslink770 wrote:
> Hi All,
> Gutenprint.
RE: [Digital BW] Gutenprint
2006-09-12 by Daniel Staver
Last time I checked Gutenprint had very good control over the inks. You
should be able to print black-only and choose between a variety of dithering
types. QuadToneRIP is based on some Gutenprint code. There used to be a
Linux compatible version of QTR, you might want to try that as well. I'm
sure you can get that version if you ask Roy.
Daniel Staver
http://daniel.staver.no
> buying my first printer.
> along the lines of what Clayton Jones describes.
> with Gutenprint. I've read the documentation, but as a newbie
> it's hard to tell whether Gutenprint allows this type of
> control. Any other options that might be useful for *nix
> computing systems?
2006-09-12 by Gary W. Weaver
Gutenprint is a PostScript thingy that is available for Windows and possibly
other OS. Linux is more standard than Windows, BTW.
gar
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Mark
Savoia
  Sent: Tuesday, September 12, 2006 6:56 AM
  Subject: Re: [Digital BW] Gutenprint
  Mark
  > Hi All,
  > Gutenprint.
2006-09-12 by Ernst Dinkla
> gar
Gutenprint used to be called Gimp-Print in earlier versions,
the last was also available in Mac OS-X versions as it was a
substitute for the lacking OS-X printer drivers at that time.
The new name was one of many changes in Gimp-print at that
stage, at the same time 16 bit computations throughout were
introduced, 32 or 64 channels can be addressed. In that sense
it is more advanced than what the other OSses offer at this
moment.
QTR is based on Gimp-print (8 bit mainly).
GutenPrint can be used in tandem with good old GhostScript
which will do the Postscript rendering. GutenPrint on itself
isn't Postscript compatible. GutenPrint isn't available for
Windows but probably usable on Mac OS-X as that is yet another
Unix offspring.
On BO use: If the 16 bit is available on the monochrome
setting in the driver (black) then it might even be better
than what is available in normal Windows and OS-X drivers. It
will not have the control QTR offers though.
Ernst
           Ernst Dinkla
www.pigment-print.com
(         unvollendet         )
2006-09-12 by Olivier
> Ernst
Ernst, would you mind explaining a bit. I would eventually see a
theoretical advantage in a 16b dithering, but in practice I'm not sure
this would translate into a better physical printing (I'm thinking dot
gain, registration, bleeding...not to mention color conversion errors
should we print colors, but that's valid for BW with QTR ICCs). What
would look like an advantage could end up in just a requirement for
more powerful systems to process the larger bit volumes. So far the new
Canon has not (to my knowledge) proven superiority from the 16b driver,
but I didn't dig deep into the matter. I just tend to assume the large
number of inks available calls for hi-bit processing to adress them.
What are your thoughts on it ?
Olivier
>> Ernst
> Olivier
In practice it will not bring much quality difference with
today's printers. But the verdict on the new Canon models
isn't ready yet. Epson brings new archival dye (Claria) models
with 6 inks, 5 droplet sizes, so it could be time there's more
than only 16 bit tables in 8 bit printer drivers. HP will have
new wide format models on the Photokina with head technology
similar to Canon's new printers. A 16 bit driver doesn't make
8 bit files unusable either. I got the impression that
Gutenprint was not considered a serious alternative in the
replies, I do not share that opinion.
Ernst
           Ernst Dinkla
(         unvollendet         )
2006-09-13 by Gary W. Weaver
Well, I can insert foot into mouth pretty well.
When I was searching for a stylus rip replacement recently, I ran accross
Gutenprint but downloaded the Ghostscript instead.
I was too lazy to double check what I downloaded.
I'd use Gimp more if it had CYMK. It probably does by now.
gar
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Ernst
Dinkla
  Sent: Tuesday, September 12, 2006 9:29 AM
possibly
  > gar
  moment.
  Unix offspring.
  Ernst
  Ernst Dinkla
  ( unvollendet )
2006-09-13 by crosslink770
Ernst,
Thanks for your response. Please say more.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Ernst Dinkla
<E.Dinkla@...> wrote:
> On BO use: <snip> It [Gutenprint]
> Ernst
2006-09-14 by Ernst Dinkla
>> Ernst
Gutenprint doesn't have the curve + linearise functions. Don't
know how well the Gutenprint driver can be tweaked to get
similar output, I guess a curve in the Gimp is then the only
option. The use of QTR profiles with the Gimp (+ something
like LCMS or Argyll) could be possible though but I doubt the
profile creation of QTR runs on Linux right now.
www.quadtonerip.com is the place to look for what is Linux
compatible.
Ernst
           Ernst Dinkla
(         unvollendet         )
Re: Gutenprint
2006-09-15 by tzinzunzan2006
This news is very interesting. So far I've resisted buying the 2400
and stuck with my 2200 (loaded it with MIS Pro inks, especially PKN),
partly because of the cost of upgrading, but mostly because for the
last few months I've been reading more posts, especially on this list,
about how with the 2400 bronzing and gloss differential problems still
persist -- although markedly less than with the 2200 inkset -- and
people are having recourse (again) to Printshield and other means to
give their prints the final look they like. Perhaps the Claria inks
will be completely solve the bronzing and gloss differential problems.
Chris
>            Ernst Dinkla
> (         unvollendet         )
