UT-3D: stability of supply & role of LK
2006-09-14 by horstenj
I'm still in mental roller coaster to decide on my printer/ink set.
I'm skipping my original plan to by a R220. Instead I'll outfit my
2100 with either the UT-7 or UT-3D inks.
I'm working with QTR. UT-7 would my current needs. On the other hand
the systematic color space approach and the split-tone potential of
UT-3D appeals to me.
My questions on the are three-fold:
1) On this form repeatedly the "beta-stage" of the UT-3D inks are
reported. Is there any view when these inks will have their final
quality level?
2) I'm not fully sure on the role of the LK ink in the UT-3D set. My
guess is that you don't need them when using QTR, but you do if you
print with the Epson driver. Right? That would mean I have the
option to experiment with sepia on the LK position(as indicated on
Paul's site) or other toners if I use QTR.
3) On the previous question: I'd like to experiment (presently just
for fun) with a green toner to get tones at the negative a-axis of
the Lab space. Can I just mix MIS yellow, (light) cyan and light
carbon? Or is that put way too simple? I realize the archival
quality of this toner will not be very good.
RE: [Digital BW] UT-3D: stability of supply & role of LK
2006-09-14 by Paul Roark
That'll never end.
> ... I'll outfit my 2100 with either the UT-7 or UT-3D inks.
>inks are reported. Is there any view when these inks will
>have their final quality level?
Soon.  Hopefully next week. (I'm off to the mountains for a few days.)
Yes.
Yes. That should work.
Have fun.
Re: UT-3D: stability of supply & role of LK
> That'll never end.
Thanks for the encouragement :-( ;o)
days.)
That is very good news and will most likely settle my choice for the
UT-3D!!
Since I will have to order the inks specifically for this: should I
go for the Cyan or the Light Cyan?
> Have fun.
That will be OK! Thanks.
