Weak black with UT-R2 in R220. Getting started.
2006-09-14 by foa208
I've been playing since one week now with my new set of UT-R2 inks
(warm) for R220. First impression is very good. I like a lot the
warm tones and the possibility of changing them using different
papers and also working with BO (much colder).
Now I'm checking linearity printing the typical 21-tone bar, and how
this linearity is influenced by the different driver and Photoshop
parameters, using also different ICC profiles from Paul's web site,
just to try.
The first problem I've noticed is that the black color (code = 0)
does not print as deep using Photoshop as it prints using QTR. The
most surprising thing is that the black darkness seems to not depend
at all on the printing parameters.
In the Epson driver, I've played with the paper type, gamma (2.2 and
1.8), and with the color setting (standard, Adobe and ICC=OFF). In
Photoshop, I've played with the color management (colors determined
either by printer or by Photoshop, with the mentioned ICC profiles).
All these parameters affect clearly to the dark and mid tones, but
the black color (code = 0) is always the same: not as dark as the
black I obtain from QTR.
I've printed from other programs that use the Epson driver and the
results are the same, so Photoshop does not seem to be causing this.
Could the Epson driver be limiting the load of black ink deposited
in the paper, or converting for some reason the code 0 to a higher
code?
I've checked also for the possible oscillations described by Paul
when fine tuning  D-max, printing a 6 tone bar from L going to 0% to
5% in steps of 1%, but there is not an appreciable difference
between them, while the QTR black is clearly darker.
One could think that the d-max of the paper is causing this, but QTR
gives a deeper black in the same paper. For money reasons, I've
doing these tests with Illford smooth multi-use matte paper.
Sure I'm doing something wrong. Any help will be appreciated,
thanks,
Fernando
