R2400 MIS EZW-4Y ink in Yellow Position
2006-10-02 by bwbonkers
Hi Paul
Thank you for this trick. I have complained in previous posts that
even though the BW prints using ABW mode and full colour ink set are
very good, I always felt that I could see a little colour spoiling
the neutrality of the print. I have just finished printing my first
prints with EZW-4Y ink in the yellow cart and the results are
fantastic. As soon as I printed a 100 greyscale file using the
standard settings the difference was very obvious compared to the
full colour ink set. With the full colour ink set I could see a very
slight yellow/green hue but getting rid of the yellow ink has
produced a very neutral greyscale.
I finally settled on H+05, V-05, best photo and paper set to premium
glossy paper. Premium glossy gave a very slightly better Dmax than
premium semi-glossy paper using Hahnemuhle FineArt Pearl. Dmax I get
is 2.212 I'm using Roy's ICC program to profile paper/ink combo.
This is only my humble observations being a keen amateur. I am still
learning but the prints on Hahemuhle paper are the best I have
managed to achieve to date. I really like this paper.
When using this trick do you print solely using the Epson ABW mode or
is there any other approach you have found to tweak the results. I do
have Roy's QTR and Bowhaus RIP both licenced but I'm getting very
lazy, Epsons ABW mode is so easy to use.
Many thanks
Peter.
RE: [Digital BW] R2400 MIS EZW-4Y ink in Yellow Position
2006-10-02 by Paul Roark
Peter,
>... I have just finished printing my first prints with
> fantastic...
I was so impressed with the 2400 Y=Carbon approach that, as you can see from
other posts, I've switched my large format approach to the same basic
formula.
>When using this trick do you print solely using the Epson ABW ...
Yes, a rip could do an even better job, but with more work.
>... but I'm getting very lazy, Epsons ABW mode is so easy to use.
Exactly.
Re: [Digital BW] R2400 MIS EZW-4Y ink in Yellow Position
2006-10-02 by edrudolpho
I've a couple of carts chipped to the yellow slot and loaded with MIS
LLK, but the ABW problem I'm seeing is more to do with magenta.  In
prints that have lots of light tones, such as a white wall, I can
clearly see a magenta wash through the light-toned area.
Ed
<paul.roark@...> wrote:
> Peter,
> > fantastic...
see from
> formula.
> Exactly.
> Paul
> www.PaulRoark.com
2006-10-07 by Steve Kale
Interesting.  Someone should pass this on to Epson.  I simple driver update
telling the driver to fire the LLK instead of the Y would achieve the same
result yet still leave the yellow in for colour.  But what happens to the
range of non-neutral ABW options?
Reply-To: <DigitalBlackandWhiteThePrint@yahoogroups.com>
Date: Mon, 02 Oct 2006 14:43:04 -0000
Subject: [Digital BW] R2400 MIS EZW-4Y ink in Yellow Position
Hi Paul
Many thanks
Peter.
2006-10-07 by Carl Schofield
Beautiful warm tone prints with no metamerism.
Carl
> driver update
> the same
> to the
> From: bwbonkers <PeterDLevis@...>
> Hi Paul
> Many thanks
> Peter.
2006-10-08 by Manuel Toledo Quinones
Paul,
Regarding the use of MIS EZ Warm cartridge in the R2400 yellow
position, MIS website says that
"This eliminates all the Epson yellow ink from the print and reduces
the use of cyan and magenta as well. The prints look even better with
this set up, plus the fade resistance is extended out way beyond the
Epson inks."
If no new profle is used, why would the amount of Cyan & Mayenta be
reduced?
Manuel
> Peter,
> > fantastic...
see from
> formula.
> Exactly.
> Paul
> www.PaulRoark.com
2006-10-08 by Paul Roark
Manuel,
The MIS perhaps should have been explicit that for a given print tone less
cyan and magenta pigments are used.  When there is yellow in the mix, that
yellow has to be offset with cyan and magenta to be neutral.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Manuel
Toledo Quinones
Sent: Sunday, October 08, 2006 10:19 AM
Subject: Re: [Digital BW] R2400 MIS EZW-4Y ink in Yellow Position
Paul,
Epson inks."
reduced?
Manuel
> Peter,
> > fantastic...
see from
> formula.
> Exactly.
> Paul
> www.PaulRoark.com
2006-10-09 by Steve Kale
I think the point was that the Epson driver doesn¹t know the yellow has been
replaced and so continues to pump out cyan and magenta.  Or am I missing
something?
Date: Sun, 08 Oct 2006 13:56:52 -0700
Subject: RE: [Digital BW] R2400 MIS EZW-4Y ink in Yellow Position
Manuel,
_____
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> ] On Behalf Of
Manuel
Toledo Quinones
Paul,
Epson inks."
reduced?
Manuel
2006-10-09 by Manuel Toledo Quinones
I believe the idea is that, as Paul explains in his message, the
assumption is that you, the user, will modify the ABW parameters when
using the EZW cardridge. Since you are using the EZW-4Y instead of
yellow, your new parameter set will use less Cyan and Magenta because
there is less yellow to correct for.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Steve Kale
has been
> something?
> From: Paul Roark <paul.roark@...>
> Manuel,
tone less
mix, that
> Paul
> _____
> Manuel
> Toledo Quinones
> Paul,
> Epson inks."
> reduced?
> Thanks,
> Manuel
The driver does not know that you’ve changed the cartridge.  It will
therefore operate independently of the change.  So for any given print, the
Adv B&W driver will use the same amount of each ink cartridge as before,
including C, M, LC and LM.
Date: Mon, 09 Oct 2006 20:36:11 -0000
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> , Steve Kale
has been
> something?
<mailto:DigitalBlackandWhiteThePrint%40yahoogroups.com> >
> Manuel,
tone less
mix, that
> Paul
> _____
> Manuel
> Toledo Quinones
> Paul,
> Epson inks."
> reduced?
> Thanks,
> Manuel
2006-10-09 by Paul Roark
Yes, I should have been more specific that for a given print tone, less cyan
and magenta (light versions) will be used.  The coordinates will change, and
the small sample image showing the tone will not be very useful to judge the
print tone.
I might add that with MIS EZ-W in the yellow spot the warm side of the ABW
range is restricted.  MIS LK and LLK help relative to the Epson versions.
But, you can print pure carbon only with an RGB approach, using a curve that
makes the print yellow on the monitor.  On Premier Art I am not able to get
a warm print out of the 2400 Y=EZW approach with the ABW mode.
While an RGB approach can take care of this problem, this approach is less
than ideal due to the yellow (now carbon) channel not having 2 midtone inks.
However, using a 1600 dpi RGB scan and the Photoshop Histogram’s Standard
Deviation as a measure, it might still be smoother than the ABW mode.
Whether this is true visually is questionable, but it looks very good.  See
http://home1.gte.net/res0a2zt/2400_RGB_Y=EZW.jpg
It may be that a rip will be the preferred approach for the 2400 and B&W
purists who want the most lightfast and smooth prints possible but still
want the full color.
  _____
Toledo Quinones
Sent: Monday, October 09, 2006 12:36 PM
has been
> something?
> Manuel,
tone less
mix, that
> Paul
> www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
> _____
> Manuel
> Toledo Quinones
> Paul,
> Epson inks."
> reduced?
> Thanks,
> Manuel
