Even dye inks are known to "bronze" in certain situations. Also, your
choice of papers is much more limited, if permanence is a consideration.
Bronzing can be eliminated or greatly reduced by spraying the prints
with a protective spray.I guess what I'm saying, experimentation is
the key to finding the ink/paper/spray combo that gives you the
results you desire.
John Nollendorfs
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Piet Weber"
<p.weber@...> wrote:
> Hi,
> Can someone advise me what black inkset to use for B/W printing on a
Epson 2100/2200? I
> hate bronzing, so I probably need a dye ink set. Lyson seems to have
this Daylight Darkroom,
> which I think is dye based, but are other brands available? I use
QuadToneRIP to print B/W
> images with a normal inkset at the moment and make my own profiles.
So I am experienced
> with this driver.
> Cheers, Piet
