Museo SIlver Rag and Innova F Type Gloss coating flaws
2006-10-08 by TK Thompson
I just spent the last 2 days trying to get a 13"x19" B&W print on these two papers with an Epson 2400. Here is what I ran into. The Museo Silver Rag has a vertical scratch running the length of the paper that is barely visible to the naked eye om the unp[rinted sheet but takes ink differently than the regular surface and is quite visible on the printed image. It seems to be on every sheet in the 20 sheet box - lot X56792701. The Innova had several sheets with surface coating overlaps that were readily apparant to the naked eye. I also have has some "pinhole" problems with this paper where the ink flakes off the paper in small dots about 1/32" diameter. Only had 2 or 3 dots per sheet. The paper was brushed with an antistatic brush followed by a shot of clean compressed air from a can to remove any particles on the surface. The vertical scratches were not observed with the Innova paper. The Innova F Type Gloss Black Max Paper was 17"x22" which I cut down to 13"x19" and had lot number 18852 29005 from the bar code on the package. It seems to me that Museo and Innova need to strengthen their QA program. I recall very few paper flaws from the old darkrooom days over the last 20 years. I didn't have any problems with these 2 papers in the 8.5" x11" sizes, only the larger sheet sizes used in this print session. Has anyone else ran into similiar problems with defects in paper coatings? Cheers, TK
