Making B&W ICC with a scanner
2006-10-10 by stasunas
Greetings,
I have been away from digital black and white printing for several
years and as a result I have to re-establish my process and workflows,
and re-learn a lot!.
I am currently working with Paul Roarks article subject about and I am
a bit confused about the Mode used when using ICC profiles. In the past
I woyld have done my adjustments, changed the grayscale image to RGB,
loaded a curve and printed. With ICC do I still change the Mode to RGB
or leave the image Grayscale and apply the ICC as I print? Thanks in
advance.
Tony
RE: [Digital BW] Making B&W ICC with a scanner
2006-10-10 by Paul Roark
Leave the image in grayscale mode.  That is one of the advantages of putting
the curves inside and ICC.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of stasunas
Sent: Tuesday, October 10, 2006 2:14 PM
Subject: [Digital BW] Making B&W ICC with a scanner
Greetings,
advance.
Tony
