In a message dated 10/24/06 10:10:38 PM, vladimir@... writes:
> I bought my Huey today. It is a cute, user friendly and affordable
> little package. The set up was easy. The screen guides you through the
> whole process. You need approx 5 minutes to calibrate your monitor.
Yes, its fast because it skips measuring all the color channels, and makes
estimations instead.
> Great - up to here! I do have some questions:
> 1/ I'm using Mac PowerBook G4 and and additional Lacie electron 19
> blue IV monitor for editing my photographs. My small LCD computer
> monitor is not important but how shall I calibrate my main (Lacie)
> monitor? Is it an independent process? And if YES then how shall I
> disable the LCD screen while calibrating?
If your LCD is brighter than the CRT, you'll be in trouble, as it will steal
your eye, and define white for you, making your CRT calibration ineffective...
> 2/ Ideally, I'd like them to match.
Makes sense to me, if both can be run in the same brightness range
effectively...
> But is it realistic?
Not with sub-hundred dollar solutions, you really need more advanced software
for monitor matching and tuning.
> Can LCD and
> CRT screens really match?
Its like harnessing a donkey and a racehorse; as long as you don't mind
donkey level results you might manage to make it work. In this case that means
dimming your LCD down to the same luminance as your CRT, and working in very dim
lighting conditions (as is always necessary with a CRT).
> 3/ Shall I leave Huey continuosly connected (to measure my room light
> temperature)?
Even people that gave Huey a good review suggested turning this feature off.
Do you want the shadow of your arm across the sensor to suddenly change the
gamma of your screen? This is for gamers, for image editing, leave it off.
> 4/ Shall I calibrate in the morning or at night (I work under daylight
> and tungsten just equally). And how often?
> If you are using a CRT with daylight in the room you are no under valid
conditions for color management. Period. You need a controlled light situation, and
a VERY dim one for a CRT to be effective. Even an LCD requires moderately dim
light for good color matching. Hopping your monitor's gamma around is not
going to magically make up for unreasonable ambient lighting conditions. Serious
color matching requires serious ambient lighting control.
One more warning: its important to calibrate with the Huey in DARK
conditions. Since the Huey does not mask a large circle around its measureing location,
ambient light leaks into the measurements, effecting dark measurement results.
So having it dark while calibrating is far more important with the Huey than
with other monitor calibrators.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
