Re: [Digital BW] Wich media for Fiba Gloss on R1800 ?
2006-11-27 by CDTobie@aol.com
In a message dated 11/27/06 5:46:01 PM, florent@... writes:
> I'm currently making Innova Fiba Gloss (IFA-09 as said on innova site)
> icc profile for my R1800 (running Efillink inks), with PFP2.05b.
> But I don't know wich type of media using for this.... Premium Photo ?
> Premium Luster ? other ?
Since you are using PrintFIX PRO, you can make a few quadrant prints to
compare differing media settings on a single sheet of paper, and be more likely to
get the optimal results with your first profile. See the Help file on the
Media Setting Check screen.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
2006-11-28 by Florent Thouret
I've just try as you suggest, with Premium Photo and Luster Premium,
and with/without gloss...
I'm a bit confused : I can't see any difference between Photo and
Luster : colors seem to be the same, so is the amount of ink...
and I can't choose between glossy or not : color parts seem to be also
the same, and the little glossy border, seen around the test picture
with gloss, is... I can see it (1/2mm), but I can't see if it's
important to have some gloss on this paper, or not... I would answer
not, but......
Who as already used it ?
