Piezography Inks with R1800 & Quadtone RIP
2006-11-26 by bcadigan
I am thinking of getting a set of Piezography inks for B&W printing on
my Epson 1800.  Has anyone had any experience with these inks on that
printer?  Specifically, did they improve your prints noticeably?  Is it
as easy as they claim to move back and forth between the Piezography
cartridges for B&W and the Epson cartridges for clor printing? So far
Quadtone RIP is giving me pretty good results in B&W with the regular
set of Epson inks.
RE: [Digital BW] Piezography Inks with R1800 & Quadtone RIP
2006-11-27 by David Whistance
Hello Bcadigan
I've used the Cone NK7 inks in an Epson R800 (the smaller version of the
R1800 but with the same print heads).  I've been very happy with its output
which is in a completely different league to the 2100 with Bowhaus RIP and
Ultrachrome inks that I used previously.  I would expect your improvement to
be on a similar scale, perhaps more so due to the single black/grey in the
R800/R1800.  The only drawbacks to the system are that it won't print on
glossy and the tone is fixed (albeit variable with paper choice), however
neither have proved to be a particular handicap to me so that I am now
looking for a reasonably priced R1800 so that I can move up a size.
David Whistance
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of bcadigan
  Sent: 26 November 2006 19:03
  Subject: [Digital BW] Piezography Inks with R1800 & Quadtone RIP
  set of Epson inks.
Re: [Digital BW] Piezography Inks with R1800 & Quadtone RIP
2006-11-27 by bcadigan
Thanks for the feedback. It's consistent with what I've heard
elswhere.  Better quality but only one tone.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "David
Whistance" <david.whistance@...> wrote:
> Hello Bcadigan
of the
its output
RIP and
improvement to
in the
print on
however
now
> David Whistance
>   -----Original Message-----
>   From: DigitalBlackandWhiteThePrint@yahoogroups.com
bcadigan
printing on
that
Is it
Piezography
far
regular
>   set of Epson inks.
2006-11-27 by CDTobie@aol.com
In a message dated 11/27/06 1:33:16 AM, bcadigan@... writes:
> set of Epson inks.
Any of the desktop printers are fairly straighforward to change inksets on.
The R800/R1800 printers, by having extra primaries make for rather more
difficult printers to produce tinted inksets for use via the OEM driver, so are
generally avoided for this (besides you can get great results for this from a $99
R2xx series printer, a more costly R800 isn't really necessary; or a 1280
instead of the more expensive R1800). So if you go with converting an R800/R1800 to
B&W, its typically going to be a more involved, RIP-bases solution, where the
extra channels are just extra channels for some RIP-based seperation scheme,
not extra primaries in the OEM driver.
The R800/R1800 with OEM ink colors are optimized for color, not for B&W;
those extra primaries don't do anything for grayscale (actually, with the OEM
driver, they don't do all that much for color gamut either, oddly enough), but
they could do a lot for grayscale if converted... but then you need to use a RIP,
and special curves or channel controls etc. for those extra inks, since they
no longer fit the OEM logic of how the printer functions. So OEM ink grayscale
printing is much better on the R2400 than the R1800; you'll see a bigger
improvement moving to a grayscale inkset for the R1800 than you would for the
R2400.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
Re: Piezography Inks with R1800 & Quadtone RIP
2006-11-27 by Steven Karafyllakis
You can go up a significant step in quality without giving up either
color, or matte/RC printing simply by using an LK in place of the gloss
cart. The only (minor) draw-backs are:
1)that some glossy papers show a bit of gloss differential. I stick to
satin-semigloss papers.
2) There are no 'canned' curves for this configuration-you'll have to
learn to make your own if you haven't already. It's not too hard, and
if you use Tom Moore's 'ideal densities' charts ( to linearize your
curves) at the back of the user's guide, you can get outstanding
results without a densitometer.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "bcadigan"
on
it
> set of Epson inks.
2006-11-27 by Matti Koskinen
I've got quite nice results toning with bibble pro's tony toning plugin
and printing with r1800 using oem inks. The results are very good and
without bad colourcasts. Especially the silver-gelatine emulation looks
good. Bibble pro has also a good  plugin for converting raw images  to
B&W, andy.
I have also qtr, and like too the results, but toned B&W has more punch,
the qtr greyscale looks little bit flat.  (I'm not yet ready to hack the
curves)
-matti
2006-11-28 by Jamie Creed
CDTobie@... wrote:
"The R800/R1800 with OEM ink colors are optimized for color, not for
B&W; those extra primaries don't do anything for grayscale
(actually, with the OEM driver, they don't do all that much for
color gamut either, oddly enough), but they could do a lot for
grayscale if converted... but then you need to use a RIP, and
they no longer fit the OEM logic of how the printer functions. So
OEM ink grayscale printing is much better on the R2400 than the
R1800; you'll see a bigger improvement moving to a grayscale inkset
for the R1800 than you would for the R2400."
just trying to understand you correctly, do you think it might be
worth testing out a neutral gray inkset in an R1800 while leaving in
the original Red and Blue to try and effect the hue. You see I've
got a redundant R1800 and I'm trying to find something useful for it
to do, by the way I'm quite happy playing around with RIP's and
spectro's,
Jamie
