Re: [Digital BW] Wich media for Fiba Gloss on R1800 ? - some colour management tips
2006-11-30 by K2 Chittin
Florent
Premium Glossy has worked fine for our customers and the profiles we've
made for them.  I know others who use Premium Semigloss instead.
I hope I'm not "teaching my grandmother to suck eggs" here and I might
get flamed for saying this but, in most cases, it does not matter what
paper type you choose in the driver for printing the target on glossy
paper so long as you use exactly the same settings once you use that
profile for real world printing.  The different paper types /may/
(usually /will/) print out slightly different coloured squares on the
target - sometimes these differences are inperceptable by the naked eye
- but these are brought back to the "correct" colour by the profiling
software.  Afterall, that's what profiling is all about: getting the
printer to reproduce a known colour based on the readings produced by
the photospectrometer, no matter what shade that colour might be on the
original printed target.
So, in theory, you can print with Premium Glossy, Premium Semigloss or
Premium Lustre.  Just keep the paper type consistent when you print with
the profile.
Have I made something simple even more confusing now?  CD ... help me
out.  You're a lot more eloquent with words than I am in most cases and
certainly when it comes to your specialist field. ;-)
K2
www.squidtechnology.com
Florent Thouret wrote:
> I've just try as you suggest, with Premium Photo and Luster Premium,
> and with/without gloss...
> I'm a bit confused : I can't see any difference between Photo and
> Luster : colors seem to be the same, so is the amount of ink...
> and I can't choose between glossy or not : color parts seem to be also
> the same, and the little glossy border, seen around the test picture
> with gloss, is... I can see it (1/2mm), but I can't see if it's
> important to have some gloss on this paper, or not... I would answer
> not, but......
> Who as already used it ?
2006-11-30 by Florent Thouret
> the profile.
In fact, that sounds correct to me... and logical, after all.
Thanks a lot for your advices !
Florent
