michael3442
Sent: Monday, December 04, 2006 7:41 PM
Subject: [Digital BW] Re: PSE 5.0 - new Convert to B&W and Color Curves
tools
I've found a little more information about PSE 5.0. Sue Chastain of
About.com has put together a walkthrough with info. about color
curves, black & white conversion, sharpening, etc.
Start:
http://graphicssoft
<http://graphicssoft.about.com/od/pselements/ig/PSE5new/index.htm?nl=1>
Color curves:
http://graphicssoft
<http://graphicssoft.about.com/od/pselements/ig/PSE5new/Curves->
Adjustment.htm
"More experienced users can expand the advanced options for full
control over highlights, brightness, contrast, and shadows. You can
see how changes affect the color curve in the diagram on the right.
Unfortunately, the color curves function was not implemented as an
adjustment layer."
Black & white conversion:
http://z.about. <http://z.about.com/d/graphicssoft/1/0/z/m/4/pse5-04.jpg>
"Now instead of being limited to a simple desaturated conversion to
black and white, users can choose from several styles of black and
white that are based on color channels from the original images.
After choosing a style, the B&W effect can be further refined by
clicking on the variation samples. It's really very simple and gives
much nicer results than the desaturate command."
Sharpening:
http://graphicssoft
<http://graphicssoft.about.com/od/pselements/ig/PSE5new/Adjust->
Sharpness.htm
"The Adjust Sharpness tool is based on the "Smart Sharpen" command
which was introduced in Photoshop CS2. I have been loving this new
sharpening tool in Photoshop CS2 and I am thrilled to see that Adobe
has migrated a simpler version of it to Elements. Not only is it
easier to use and understand, but the sharpening results are much
better and there is less tendency to get "the halo effect" from
oversharpening."
It would be great to read some more comments from you guys on how
this version of
PSE may be suitable for black & white printing as a substitute for
PS. Thanks.
Michael
