R2400 ? cost for PK to MK changeover
2006-12-29 by Scott Jones
Has anyone ever figured out the cost in ink for the changeover from PK to MK ink and back again in the R2400 printer? Does it just flush out the black line on the changeover or does it flush all the colors too thus wasting a ton of ink? Thanks for any help or experience you can give. And Happy New Year! www.scottjonesphoto.com
2006-12-29 by Manuel Toledo Quinones
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones" <peanutdogs@...> wrote: > > Has anyone ever figured out the cost in ink for the changeover from PK > to MK ink and back again in the R2400 printer? Does it just flush out > the black line on the changeover or does it flush all the colors too > thus wasting a ton of ink? Thanks for any help or experience you can > give. And Happy New Year! > > www.scottjonesphoto.com > I think my printer flushes all the colors. My impression is that a single change can take away up to about 1/4 of some cartridges, less of others. I have switched inks only a few times, so other might be able to provide more reliable numbers. Manuel
2006-12-29 by Clayton Jones
Hello Scott, >Has anyone ever figured out the cost in ink for the changeover from PK >to MK ink and back again in the R2400 printer? Does it just flush out >the black line on the changeover or does it flush all the colors too >thus wasting a ton of ink? Thanks for any help or experience you can >give. And Happy New Year! Are you sure you mean the 2400? The 2400 doesn't have "lines" that need flushing, the carts sit directly on top of the head. I've found that switching between PK/MK is basically like an ordinary cleaning cycle. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2006-12-30 by Scott Jones
Hi Clayton, Thanks for the response. Sorry about my imprecision on using the term "lines". I really just mean the cleaning of the R2400 mechanism. Do you know whether all the colors are cleaned out or just the black part? If it is just the black, then I suspect there is minimal cost. But another poster suggested that the changeover used up 1/4 of the color carts which is a whopping amount of ink. Any experience? Scott http://www.scottjonesphoto.com --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > Hello Scott, > > >Has anyone ever figured out the cost in ink for the changeover from PK > >to MK ink and back again in the R2400 printer? Does it just flush out > >the black line on the changeover or does it flush all the colors too > >thus wasting a ton of ink? Thanks for any help or experience you can > >give. And Happy New Year! > > Are you sure you mean the 2400? The 2400 doesn't have "lines" that > need flushing, the carts sit directly on top of the head. I've found > that switching between PK/MK is basically like an ordinary cleaning cycle.
> > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm >
2006-12-30 by Clayton Jones
Hello Scott, >Thanks for the response. Sorry about my imprecision on using the >term "lines". I really just mean the cleaning of the R2400 mechanism. >Do you know whether all the colors are cleaned out or just the black >part? If it is just the black, then I suspect there is minimal cost. >But another poster suggested that the changeover used up 1/4 of the >color carts which is a whopping amount of ink. Any experience? I mostly use MK and have changed over to PK and back three times. I didn't attempt any close measurements, but I certainly would have noticed if it used that much. I don't know if it only cleans the black channel or not, but my sense of it is that at most it would be like a normal cleaning cycle. I don't think it's outrageous, but like cleaning cycles it uses some so I try to plan ahead for my PK sessions and do it as infrequently as possible. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2006-12-30 by Peter Marshall
Hi Scott, Like Clayton, I've not noticed any large changes in color ink levels on swapping PK/MK. Certainly if it was anything like 1/4 of a cart I would have been running out of some color inks on almost every swap, and it just doesn't happen. I've also read some very exaggerated reports of the amount of ink wasted on cleaning cycles. Perhaps some R2400s are somehow more wasteful than others, or perhaps people post who don't use the printer? Although they do get through the ink, and aren't cheap to run, I think most of it goes on the prints. So long as you batch your prints rather than swap over every time you make a print I don't think the PK/MK switch is a major problem. Peter Peter Marshall petermarshall@... _________________________________________________________________ My London Diary http://mylondondiary.co.uk/ London's Industrial Heritage: http://petermarshallphotos.co.uk/ The Buildings of London etc: http://londonphotographs.co.uk/ and elsewhere...... Clayton Jones wrote:
> Hello Scott, > > >> Thanks for the response. Sorry about my imprecision on using the >> term "lines". I really just mean the cleaning of the R2400 mechanism. >> Do you know whether all the colors are cleaned out or just the black >> part? If it is just the black, then I suspect there is minimal cost. >> But another poster suggested that the changeover used up 1/4 of the >> color carts which is a whopping amount of ink. Any experience? >> > > I mostly use MK and have changed over to PK and back three times. I > didn't attempt any close measurements, but I certainly would have > noticed if it used that much. I don't know if it only cleans the > black channel or not, but my sense of it is that at most it would be > like a normal cleaning cycle. I don't think it's outrageous, but > like cleaning cycles it uses some so I try to plan ahead for my PK > sessions and do it as infrequently as possible. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > > >
2006-12-30 by Manuel Toledo Quinones
Scott, I use refillable cartridges, and they may behave differently than epson originals. I believe, however, that all colors are used in the cleaning cycle that the printer does after I change a single cartridge. Manuel --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Scott Jones" <peanutdogs@...> wrote:
> > Hi Clayton, > > Thanks for the response. Sorry about my imprecision on using the > term "lines". I really just mean the cleaning of the R2400 mechanism. > Do you know whether all the colors are cleaned out or just the black > part? If it is just the black, then I suspect there is minimal cost. > But another poster suggested that the changeover used up 1/4 of the > color carts which is a whopping amount of ink. Any experience? > > Scott > > http://www.scottjonesphoto.com > > --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" > <cj@> wrote: > > > > Hello Scott, > > > > >Has anyone ever figured out the cost in ink for the changeover > from PK > > >to MK ink and back again in the R2400 printer? Does it just flush > out > > >the black line on the changeover or does it flush all the colors > too > > >thus wasting a ton of ink? Thanks for any help or experience you > can > > >give. And Happy New Year! > > > > Are you sure you mean the 2400? The 2400 doesn't have "lines" that > > need flushing, the carts sit directly on top of the head. I've > found > > that switching between PK/MK is basically like an ordinary cleaning > cycle. > > > > Regards, > > Clayton > > > > > > Info on black and white digital printing at > > http://www.cjcom.net/digiprnarts.htm > > >
Thanks everyone for your thoughts. I almost exclusively use PK, but want to try MK for the greeting cards that I occasionally make. PK looksawful on mat paper. I just didn't want to do this if it was going to cost me a fortune in ink. I will give it a whirl. Happy New Year http://www.scottjonesphoto.com --- In DigitalBlackandWhiteThePrint@yahoogroups.com, Peter Marshall <petermarshall@...> wrote: > > Hi Scott, > > Like Clayton, I've not noticed any large changes in color ink levels on > swapping PK/MK. Certainly if it was anything like 1/4 of a cart I would > have been running out of some color inks on almost every swap, and it > just doesn't happen. > > I've also read some very exaggerated reports of the amount of ink wasted > on cleaning cycles. Perhaps some R2400s are somehow more wasteful than > others, or perhaps people post who don't use the printer? Although they > do get through the ink, and aren't cheap to run, I think most of it goes > on the prints. > > So long as you batch your prints rather than swap over every time you > make a print I don't think the PK/MK switch is a major problem. > > Peter > > Peter Marshall > petermarshall@... > _________________________________________________________________ > My London Diary http://mylondondiary.co.uk/ > London's Industrial Heritage: http://petermarshallphotos.co.uk/ > The Buildings of London etc: http://londonphotographs.co.uk/ > and elsewhere...... > > > > Clayton Jones wrote: > > Hello Scott, > > > > > >> Thanks for the response. Sorry about my imprecision on using the > >> term "lines". I really just mean the cleaning of the R2400 mechanism. > >> Do you know whether all the colors are cleaned out or just the black > >> part? If it is just the black, then I suspect there is minimal cost. > >> But another poster suggested that the changeover used up 1/4 of the > >> color carts which is a whopping amount of ink. Any experience? > >> > > > > I mostly use MK and have changed over to PK and back three times. I > > didn't attempt any close measurements, but I certainly would have > > noticed if it used that much. I don't know if it only cleans the > > black channel or not, but my sense of it is that at most it would be
> > like a normal cleaning cycle. I don't think it's outrageous, but > > like cleaning cycles it uses some so I try to plan ahead for my PK > > sessions and do it as infrequently as possible. > > > > Regards, > > Clayton > > > > > > Info on black and white digital printing at > > http://www.cjcom.net/digiprnarts.htm > > > > > > >
