UT3D ink + QTR instructions
2007-01-01 by gochatunbdotca
Does anyone have a from-the-ground-up set of instructions for using MIS Associates'
UT3D inks on an Epson 2200 with the PrintFix Pro profiling system?
I find this sort of thing much more difficult to sort out than darkroom work... it's so
disconnected from tangible, physical objects and processes that I have trouble keeping all
the bits and pieces of information in my working memory.
Paul Roark's descriptions of UT3D inks assume a level of understanding that I do not have
at present, and he's such a determined experimenter that he's moved on to new projects
before I've figured out what he was doing last year...
Assume I want to create profiles for an Epson 2200 loaded with UT3D inks in the standard
positions.
Assume that I will be printing monochrome images, starting out with Gamma 2.2
embedded profiles (or something else, if it would help).
I can run a paper through the PrintFix Pro workflow, printing, reading and creating a
profile from the 225 patch target.  (I do this successfully for color profiles.) Is there any
advantage to including the extended gray target as well?
Now what? I assume that I do not need anying further to "linearize" the profile. ???
Step by step, how do I go about creating profiles or Photoshop curves that will change only
the color or tone of the image?  My first attempt at a PrintFix Pro B&W profile resulted in a
very cool image tone, and I would like to warm it up.
Thanks.
Myron
Re: UT3D ink + QTR instructions
2007-01-01 by Joost Horsten
Myron,
Your subject says "QTR", with which I might be of help (just having
gone through this process), but your post talks about Printfix Pro (no
experience with that). I assume you mean the latter.
Joost
Oops! I started out thinking about doing this with QTR, but in writing the message I decided
it might be simpler to stick to the Epson driver.
I use QTR too, so help with that and UT3D would be more than welcome!
Indeed, one of my problems is probably that there are too many variables for me to get my
feet on the ground.
> Joost
2007-01-01 by robert49brake
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "gochatunbdotca" <goch@...>
Hello Myron, I can help get you forward but my workflow is gradually evolving over my
free time during the holidays so nothing is fully formed or down pat.
I'm using an R220 but the UT3D/PFP approach will be the same.
1) I use MIS PKN in the K position for glossy papers and Eboni for the matte.  I don't know
of a way yet to replicate Paul Roark's system using curves to hold back the Eboni on the
glossy papers.  I get decent d-max out of everything so far but I can see room for
improvement somewhere within the profiles.  For example with Crane Silver Rag I can get a
d-max of 2.28 out of one patch on the PFP printout but I can only get 2.2 out of a 21-step
image printed through the profile.  Just looks like there is more work to do there.
2)  I was using the 225 patch printouts originally but I am now tending to use the 150
patch and I'm not really sure the Enhanced Black printout would add anything with the
UT3D inkset.  I'd be interested in hearing from others.  I also find that the PFP profiling
process gives a reasonably good linearization.  I think there is room for improvement and
it can probably be found in the PFP advanced processes under a different name.
3)  I go to the print dialogue with Adobe RGB images primarily and with sRGB occasionally
but the RGB is important with the UT3D and PFP.  With the PFP profiles you are actually
printing a color image with a color inkset, just that it is limited in its color.  Paul's method
prints from a grayscale image and you have an ability to view the tonality on your monitor
using a unique function of the QTR create icc profile, but it is different than the RGB
approach of PFP.  (And I assume you have PFP 2.0. and PS CS or CS2)
4)  Now we get to the variables.  I started this project with CS-2 and went looking for ways
to tone the prints through PS, again, treating the image as a color image, rather than
making individual curves for different profiles and a greyscale image.  What I found I liked
best was Image/Color Balance.  There you can influence the color with three sliders and
three area settings (highlights, mid-tones, and shadows).  The yellow/blue slider, of
course, has the strongest influnce on warm to cool and corresponds to the b* axis of
UT3D.  The other two have less influence and I'm still working on getting my head around
exactly what angle  the a* axis of UT3D takes.  Suffice it to say a great deal can be done
instantly with the yellow/blue slider and lot's of playing can be done with the other two.  I
activate the profile for the paper I'm going to use in View/Proof Set-up/Custom then I
engage View/Gamut Warning.  I also change the default gamut warning grey to an oddball
chartruese or something similar in Photoshop/Preferences/Transparency and Gamut...
this will give you an instant warning when and where your toning has exceeded the
capability of the inkset.   You can use this command and go cooler or warmer across the
image by using the same settings in all three areas, (highlight, midtones, shadows) or you
can vary them quite easily: warm highlights, nuetral midtones, cool shadows etc.  Fairly
broad strokes but very easy to work.  The above method might be a little too easy as it can
lend itself toward unreal prints if you're not careful.  Masks could still be used for split
toning in different parts of the print.  (A note on the above process.   The UT3D gamut
through the PFP profile is very sensitive and your monitor's capabilities are important.  For
the last week I've been working on my laptop monitor only and it is very susceptable to
ambient light and can easily overshadow the affect of the toning done in PS.  So a well
calibrated monitor and nuetral workplace seems to be important.  Eventually that was
overcome by simply making some prints and comparing them the next day in day light.
I'm eager to get back to my normal monitor and workspace for this.)
I also transferred all of this to CS3 Beta recently and there are a few differences.  The first
is that you can get to Color Balance through Adjustment Layers now so the adjustments
are Smart and easy to change.  There is also a new B&W adjustment layer that can give you
even more tone control in a similar mannner by engaging the profile and Gamut Warning
and seeing it on screen (of course this precludes a calibrated screen) but the B&W
adjustment Layer doesn't have (or I haven't found a way without resorting to masks) to
affect only particular tonal areas of the image.
6)  I've gotten very good prints with this method though there is probably room for
improvement.  The same print with Paul's profile using the basic approach he has outlined
is slightly different, slightly nicer contrast but with a small loss of shadow detail.  That
could probably be remedied in the PFP advanced processes.  There is also a measurably
smoother plot of the a* and b* axes using Paul's profiles although the PFP method does
give a very nuetral looking print.  I tried Paul's method of profiling and found myself
having a hard time getting my head around the curve process both as it relates to holding
back the Eboni on the glossy papers and getting a handle on the relationship between the
ink positions and how they relate to the a* and b* axes of the UT3D.  I think I'll probably
keep working on Paul's process as I think it can inherently produce a better print albeit
with a greater amount of work.  That said I'd love to here of any methods to apply
correction curves to the PFP profiles that would smooth out the a* and b* axes.  (There
probably already is within PFP's advanced diologues and the real problem is me getting my
head around the above mentioned areas.)
Right now I have a long project that needs various tones (duplicating photes from over a
hundred year period) and the UT3D will work wonderfully using the PFP approach, but in
the long run I think I'd like to either get Paul's approach down or find a way to even better
nuetralize the PFP profiles for any new work.
I'm sure there is something I've missed and hopefully some others are playing with the
PFP/UT3D approach.
Robert
