Re: [Digital BW] UT3D ink + QTR instructions
2007-01-02 by CDTobie@aol.com
In a message dated 1/1/07 11:46:38 AM, goch@... writes: > Does anyone have a from-the-ground-up set of instructions for using MIS > Associates' > UT3D inks on an Epson 2200 with the PrintFix Pro profiling system? > Just load the inks, choose a media setting that doesn't clog the shadows excessively, read the 225 patch color target (called High Quality Target), print the one page target, read the patches, then build the profile. If you want to open the shadows further, then use the advanced slider with a positive value in the shadow detail section. It takes the software longer to calculate a grayscale inkset's profile than a color inkset, so don't panic when it "freezes" in the calculation process, this is normal, it will come out of it once the calculations are complete. Once you have your profile for the UT-3D inks with that paper and printer, you can use it with the Photoshop Custom Proof setup option to adjust your (RGB format) image to tint it, if you aren't looking for neutral results. C. David Tobie Product Technology Manager ColorVision Business Unit Datacolor Inc. CDTobie@... www.colorvision.com [Non-text portions of this message have been removed]
