Wildly varying Dmax
Wildly varying Dmax
2006-12-31 by Joost Horsten
Hi all
I've been redoing some QTR curves from 1440 to 2280 dpi lately and re-
encounter an effect I've was not sure it was there actually. My
measured Dmax seems to vary quite wildy when I measure the same step
wedges on different moments, also after drying properly.
Currently, I'm trying different ink limits/black boost/overlap QTR
settings. But the differences between the settings seem to disappear
in the noise of my measurements.
My setup: QTR/Windows/Epson 2200/UT3D/Enhanced Matte/Eye-One.
Most of the time I measure L*/Dmax values between 16.3/1.67 and
17.0/1.64, but not seldom I get values of around 19/1.56.
Occaisionally even higher. These variations do not occur within one
measurement session: repositioning and measuring again gives some
normal measurement noise (L* +/- 0.2). But when I repeat a
measurement a or some days later, the varations are much larger.
I do take care that I allow for drying overnight. My feeling is that
is has something to do with changes/contaminations of the surface of
the eboni ink. For instance, if I print a second step wedge on the
same paper, I tend to see a roller mark on the first step wedge. I
can't substantiate this yet, but I also have the feeling that a layer
with more ink (giving a better the Dmax at t=0) is more prone to this
effect (and giving a worse dmax later).
Any clues here?
Joost
Re: Wildly varying Dmax
2006-12-31 by Greg
Do you calibrate your i1 every time you use it? (every day)
Just wondering if it drifts enough without a fresh calibration to
cause this.
If your i1 is very old it may need to go back to be re-certified.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
> cause this.
Hi Greg,
I use GretagMcBeth Profilemaker for doing my spot and chart
measurements. That forces a calibration step before every measurement
series. The Eye-one is only a few months old.
Joost
2006-12-31 by Greg
Joost,
It could be that you are putting too much ink down, but that normally
shows up right away and doesn't take days like you are seeing. Do you
have something that is fairly stable like a Macbeth chart that you can
measure? That way you can check for consistency between sessions.
2007-01-01 by Joost Horsten
First of all, a happy 2007 to you all! I hope in this year the world
will not be as black and white as our pictures ;-)
> Do you
The same thought occurred to me. I did checks with both the GMcB
Digital Color Checker SG (a semi-matte plastic camera target) and the
GMcB Eye-one Scan Target 1.4 (a glossy paper target).
There seems to be nothing electronically wrong with my Eye-one. With
the glossy scan target the measurements were immediately very
reproducible (noise of L* = 0.1/0.3). With the semi-matte camera target
I did have some performance issues on the start. Especially the blacks
showed a similar problem (L* varying between 7.4 and 11). Upon closer
inspection however it turned out to be the result of a very slight
(frankly invisible) contamination. After cleaning the results were very
reproducible, also the L* values dropped. Perhaps cleaning is not even
the right word. I rubbed the targets with my finger after which they
looked a tiny bit "smoother". The midtones and higlights were much less
susceptible to this effect.
So this probably points to the source of my problems with the EEM/Eboni
targets. I have noticed before that the eboni prints are quite
sensitive (note my remark on the printer rollers in the original post).
I have done nothing special with the targets, neither handled them
roughly, but also did not protect them in a special way. The have just
been laying around for a day or two. But that's maybe not the way to
deal with them.
Going back to the semi-matte camera target, another, slightly related
explanation could be that I did not actually clean the target, but put
some tiny bit of grease on them with my finger, thereby "polishing" it.
In that way, it might be on optical effect, perhaps similar to the
difference between matte and glossy papers. Then again, it would be an
inherent effect of the matte print.
Does this make sense to anyone?
Joost
Re: [Digital BW] Re: Wildly varying Dmax
2007-01-01 by Ernst Dinkla
A happy 2007 for all.
> deal with them.
It could be different on the Eye One but my SpectroCam is
quite sensitive to the distance to the target and the angle.
The automatic  measuring setup with an old HP plotter had the
spectrometer slightly higher at first and the results were
darker readings. A slightly different angle of the head on the
patch showed similar changes. I had already made another strip
guide that allows longer strips to be measured manually and
that works good. The head doesn't touch the strip but is at
the right height and a thin PET foil protects the rest of the
target when the spectrometer is running over it.
I'm an advocate for multiple targets and multiple measurements
+ averaging. The SpectroCam does that already on its way over
the patches, between 7-15 readings per patch. But I use more
targets where possible, the targets printed in another
direction etc.
An interesting fact about the HP Z3100 and Z2100 is that the
integrated calibration and profiling measures per patch and
the dark patches get a longer time for the measurement.
Something that is difficult to achieve with strip reading or
one should increase the size of the dark patches.
Any change in the surface of matte black should give different
readings.
Met vriendelijke groeten, Ernst
|  Dinkla Grafische Techniek  |
|     www.pigment-print.com    |
|             ( unvollendet )            |
Hi Ernst,
Thanks for your suggestions.
I checked this and it does not seem to explain what happens. The eye-
one is well constructed to keep the angle fixed. Also distance seems
to be wel controlled, both with and without guide. Furhtermore, if I
artificially increase the distance a bit, the meaused l* LOWERS (i.e.
less light light reflected, which is logical to me) instead of
increasing (what is what I find if the measurement seems not to be
OK).
> direction etc.
Given my recent experience, I'll will make this common practice as
well. However, my current results seem to be obscured by systematic
artifacts. No stochastic process will eliminate this.
That's interesting indeed, confirming that black readings are more
prone to errors.
> readings.
I come to that conclusion as well. It's not illogical. My explanation
is that any contamination or damage increases the scattering at the
surface and, by that, increases the reflectivity of the surface. Is
that what you mean as well? But I'm surprised by the size of the
effect.
Joost
>> readings.
> effect.
Given the up to 0.6 D differences between matte and gloss
prints (with PK) it can be expected. A superb gloss top coat
applied on a textureless matte print (with MK) will  show
similar differences. It is the well known effect you get with
spot varnishing on a matte or semi-gloss black offset print.
Different visual density and a more selected view angle for
the deeper black of the varnished area. So the grease
(varnish) or marks (texture is reduced like in paper
satination) reduce the scattering and the spectrometers
light/sensor geometry results in less light reflectance to the
sensor itself as it isn't in the the direct angle of reflection.
Once we had a discussion here on the differences between dye
ink matte Dmax and pigment ink matte Dmax. That's a harder nut
to crack.
|             ( unvollendet )            |
2007-01-02 by CDTobie@aol.com
In a message dated 1/1/07 1:50:37 PM, j.h.j.h@... writes:
> prone to errors.
Yes, reading darkness with a light sensor is less effective than reading
light with a light sensor, this is true of all such devices.
C. David Tobie
Product Technology Manager
ColorVision Business Unit
Datacolor Inc.
CDTobie@...
www.colorvision.com
