C88 and MIS EZ-UT settings...
2007-01-08 by rlyadoptr
Greetings,
This question should probably be directed at Paul Roark, but I'm
posting in case anyone else can provide some insight...
I recently converted my C88 to MIS EZ-UT inks and I am printing
primarily on Crane Museo Silver Rag.  I am getting good results but I
would like to confirm my tests against Paul's recommended settings to
ensure that I am getting the most out of these inks.
Unfortunately, there appear to be some inconsistencies in the C88
Glossy instruction PDF
(http://home1.gte.net/res09aij/C88_EZ_Slider_settings.pdf).
Specifically, in section 2b, in CS(CS2/CS3) if the print color
management setting is to not have PS do any color management, the
printer profile drop list is disabled; i.e. I can't select the ICC
that matches my paper.
Also, if using ICCs, should color management not be disabled in the
print driver contrary to what is specified in section 3 "Driver
Properties"; i.e. shouldn't this be Color Management->ICM->Off
instead of Color Management->Color Controls->Gamma 2.2?  If I am not
mistaken, what is specified would lead to double profiling or double
color management.
I apologize in advance if I am misunderstanding the instructions.
Thanks in advance,
-jk
RE: [Digital BW] C88 and MIS EZ-UT settings...
2007-01-09 by Paul Roark
You're right, there seems to be a mistake in the pdf.  For an ICC, you need
to Let PS Determine the colors.
Frankly, the C88 write up was a rush job that may have other mistakes.  I
haven't use the machine for a while.  Let me know if there are other errors.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of rlyadoptr
Sent: Monday, January 08, 2007 1:07 PM
Subject: [Digital BW] C88 and MIS EZ-UT settings...
Greetings,
(http://home1. <http://home1.gte.net/res09aij/C88_EZ_Slider_settings.pdf>
color management.
Thanks in advance,
-jk
