Jamie,
I now tend to have the "neutral" curves go, more or less, smoothly from the
paper white to the black values for Lab a & b. I have more of the change
take place at the white end, so that by 50% it's essentially neutral or
close to the K value. What I don't do much any more is fight the paper
white at the light end where lots of it is showing through between the ink
dots, unless I'm intentionally trying to do a split tone.
I also don't consider Lab a = 0 to be "neutral." I like a slight positive
"selenium" look.
I'm not sure anyone can actually see a 0.5 variance in a print. At the
point you're at 0.2, you're fighting the noise of the systems. For
perspective, my X-Rite and PFP spectros can disagree with each other by up
to a full 1.0 a and b.
If you have a silver print you like, consider using it as a standard and
visually evaluating the inkjet test strips next to it. Lighting and
adjacent colors can affect how the test strip will look.
Don't let the small changed in tone drive you crazy.
Good luck.
_____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Jamie
Creed
Sent: Saturday, January 13, 2007 12:19 PM
Subject: [Digital BW] Lab a and b values for a neutral curve?
What is the opinion of folks with regards to the Lab a and b values
that should be strived for when producing a neutral curve?
I've been playing around for a good few days now trying to produce a
neutral curve, and seem to be going around in circles at the moment,
with values within plus or minus 0.5 for both Lab a and b; are these
figures considered OK or should I continue with more iterations?
I'm using QTR with a 1290s and a UT3D inkset, and using an XRite Pulse
for my readings,
Jamie.
