Re: [Digital BW] Re: ink cart capacity?
2007-02-04 by Kurt Mahan
I keep hearing of a chip resetter. What is it and why do you use it. I have an Epson 2200 and 1800. I am tart using the UT7 inks in the 2200 for a dedicated b/w printer.
kurt
----- Original Message ----
Sent: Saturday, February 3, 2007 10:55:10 AM
Subject: [Digital BW] Re: ink cart capacity?
Hi Alan;
Yes the 3800 holds 80ml per cart. The smaller carts Epson carts hold
about 15ml, but you'll never actually use all of it, the most you'll
get out is about 11-12ml unless you use 3rd party spongless carts and
a chip re-setter.
Steven Karafyllakis
http://www.stevekph oto.com
--- In DigitalBlackandWhit eThePrint@ yahoogroups. com, "Alan Zinn"
<lookaround360@ ...> wrote:
> What is the capacity of the Epson 2200, 2400 and 1400 ink carts?
> I believe the 3800 carts hold 80ml - correct?
> Thanks,
> AZ
Chip Resetter (was ink cart capacity?)
2007-02-04 by Paul Roark
>I keep hearing of a chip resetter. What is it and why do you use it. ...
See http://www.inksupply.com/qb7.cfm
If you re-fill a cartridge, you need to re-set the chip so that the printer
knows the cart is once again full.
