Re: 2200 Flashing Red Lights / Resetting Waste Pad Counter - Issue
2007-02-11 by Seth
Having been on the other side of the fence I can understand Epson's desire
to not tell all.
You have NO idea how many BS/nit-picky/DFO calls you get from customers.
Giving them such ammo would wreck your life.
Keep in mind that some of those tests may look a little "off" to you but be
well in normal tolerance.
Being able to tweak it yourself is a real plus for you since you understand
it.  Most of the world has no "need to know."  And, definitly no capacity.
Seth
 Posted by: "dizpark" didzis.poreiters@... dizpark
    Date: Fri Feb 9, 2007 3:06 am ((PST))
Unfortunately, also the platten gap is out of
whack - and this can be adjusted only with the help of a special
platten gap adjustment gauge at an authorised Epson service. Again,
I think that Epson should have included this possibility to print
out test patterns with their standard driver/service utilities, so
that the end users knows if the printer has an adjustment problem.
After my experience, I suspect that there may be a lot of Epson
2200/2100 printer owners that are less than happy with their
printouts (because there is no standard to compare to) and think
that these are the limits of what their printer can do, when
actually the printer is not adjusted correctly.
Checked by AVG Free Edition.
Version: 7.5.432 / Virus Database: 268.17.33/678 - Release Date: 2/9/2007
16:06
2007-02-11 by dizpark
Seth!
I can see your point about over obsessive customers (I am obsessive
too :-) not willing to interpret and understand the results of this
or that test pattern and instead bugging the tech support ad
nauseum. Perhaps this was one reason why Epson removed all those
service manuals from their website some time ago. But I am rather
happy too know now a little bit more how my printer works (or
doesn't).
Anyhow, my printer is off to adjustment at an authorised service
centre (PG is so very obviously off - the print head is actually
hitting/scraping paper surface on the right hand side of A3 paper).
Let's see how it folds out and if my interpretation of service
programme's printouts have been right or wrong.  Also I will try to
determine if the the print quality improves after adjustment.
Didzis
Epson's desire
> to not tell all.
customers.
you but be
understand
capacity.
> Seth
