Thanks Paul. Terrific information. Wasn't thinking of using the
Eboni to dilute, but the MIS Archival Black as suggested on the site.
The clear base should be all I need as I don't print b&w on anything
but matte stock.
It may all be moot anyway. If I can get what I want with the UT2 inks
then making my own wouldn't be necessary. But still might be an
interesting experiment.
I hadn't considered the UT R2 inks because they weren't recommended
for the 1280. I guess what I was thinking of was something along the
lines of the FSN set but with 2 additional shades for perhaps even
better tonality and gradation.
<paul.roark@...> wrote:
> >I've got a second 1280 that I'm going to use exclusively for b&w.
> > ... thinking about making my own.
> >I very rarely tone b&w prints and when I do, I get
> >very good results using my colour printer
> >so am looking at a set of just black/grey inks.
> Remember that the straight carbon inks are quite warm, about half way to
> sepia. So, a monotone neutral ink is, in fact, a toned ink.
> The whole "variable tone" approach came only after I found that
getting a
> neutral tone on differing papers required different amounts of
toning. As
> such, it was easier to have the toner be separate from the carbon
inks and
> use software (curves or other profiling method) to achieve the tone
I was
> after.
> If you do want any toning, you'll find the inks often need more cyan
or less
> magenta (or R800 blue recommended if using MIS inks) in the shadows.
For
> the midtones and lighter, a ratio of 2 R800 blue to 1 cyan is about
right
> for a slight positive Lab A in the final mix. This too will vary,
however,
> which is why I went dual toners (3D or 4K+cm approaches).
> If you want a pre-mixed monotone neutral set, the UT-R2 will almost
> certainly work on the 1280. A warm (carbon) ink in the yellow spot gets
> some variability with the EZ-W being an option that may work better
than the
> R2-light warm ink.
> >In addition to the Eboni Black, I'm considering 10%,
> > 25%, 40%, 55% and 70% black formulations.
> In the 4K+cm approach, I go from Eboni to K4 PK, which is probably
close to
> your 70% target.
> I would not recommend trying to dilute Eboni. Start with MIS PK. I
have
> diluted Eboni and it loses its relatively neutral tone.
> To dilute down, if you want to use glossy paper, don't use the clear
base
> MIS sells. Their Glop appears to be the same as the clear (slightly
yellow)
> base that is used for diluting the latest inks.
> The standard dilutions are about a 1:3 ratio. That is, LK is about
.3 MP
> PK; LLK is about .3 LK. Using these standardized inks is useful. (Note
> that the K4 PK is a lower load than the older MIS 7600 or MP PK --
which are
> now the same inksets.) In the inks like UT2 and R2, the light inks
are .3
> of the dark inks. The light carbon in the MIS inks is about .5 LK. (The
> markings on the bottles MIS sells or used to sell, like "25%" etc., were
> never actual dilution ratios. They are just relative markings to
let people
> know which ink is more dilute.)
> > And I typically do duo or tri toning ...
> The 4K+cm could do that and would work on the 1280. See
> http://home1.gte.net/res09aij/4K+.pdf
> Have fun with the project.
> Paul
> www.PaulRoark.com
