UT-3d profiling
2007-02-27 by Myron Gochnauer
>> I'm using: >> >> PrintFIX PRO 2.0 >> Epson 2200 >> MIS UT-3d inks >> QTR-Create-ICC-RGB.app (Mac) >> Embedding_Photoshop_Curves_in_ICCs.pdf >> UT-3D_Readme.pdf > > Someone else will assist with your CreateICC workflow, but I > wanted to > encourge you to just print out the PrintFIX PRO 225 patch target > via the RGB > driver with your UT-3D inks, build a PFP profile from the target > print, and try > printing to the RGB driver though that... its an alternative worth > considering! > > C. David Tobie thanks for the response. I've already done this successfully. Unfortunately, the approach is limited by the type of ink in the black position. I get a nice, no nonsense profile for matte papers (Eboni in black position), but have to switch to PhotoBlack to work with glossy surfaces. One of the nice things about UT-3d is that you can print on both matte and glossy paper by changing only the profile, not the ink. But, of course, that requires some pretty weird "color" profiling, which is not going to be PFP-able. Myron
