R1800 Received
R1800 Received
2007-03-15 by Steve
I received my $300 refurbished Epson R1800 the other day.
Set-up and installation was trouble free.  I loaded the Generations G7
ink I received from Media Street at a bargain price.
Inks charged and software installed, I realized I'd forgotten one
little thing...paper!  I don't want to waste my expensive Pictorico
testing the printer out, so I'll be picking up something today at
lunch.
Forum question:
Is it ok to list something on topic for sale here?
Re: R1800 Received
2007-03-16 by Steve
Well, I experienced some bad banding issues and the head cleaning test
patterns would not clear up.
I removed the Generations inks and installed the Epson original inks.
It all came back in to alignment and is now putting out beautiful color
prints.
I'm back and forth with the Media Street support people right now.  I'm
trying to figure out if I should even bother to try putting their inks
back in or not.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steve"
G7
> lunch.
> Forum question:
Re: R1800 Received
2007-03-16 by sinar001
Well, the "bargain priced inks" weren't such a bargain after all! I
sure would not put them back in! Look at all the time and effort you
have wasted thus far.
John Nollendorfs
> prints.
> back in or not.
> G7
> > lunch.
> > Forum question:
Re: R1800 Received
2007-03-16 by Greg
My comments from before still stand.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "sinar001"
> John Nollendorfs
test
inks.
color
> > prints.
now.  I'm
inks
> > back in or not.
Re: R1800 Received
2007-03-16 by Steve
Just seems like someone aught to be able to put out a good product at
a reasonable price. The prices Epson charges for ink seriously affect
how much printing I'm able to do.
I guess ink/carts must be more complicated than they look.
Off topic here, I guess...
Besides the banding problem, the color from the Epson inks is just so
much better than the Generations.  Really, the Generations prints
look to be about 20% desaturated versions of the Epson prints.
Back on topic....
I'm surprised at how good the black and white output is from the
R1800.  On mat paper, the balance is a bit cold.  On glossy, it seems
right on.
A close look shows that the tonal transitions aren't what I would
like them to be, but I could show an 8x10 to a non-photographer and
they'd be thrilled.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Greg"
I
you
> > John Nollendorfs
> > --- In DigitalBlackandWhiteThePrint@...m, "Steve"
Lord, I am the Idiot of all Idiots!
2007-03-16 by Steve
Media street advised me to let the inks I removed sit overnight and
try again.
Instead, I installed the second set of inks I'd bought from them (in
all my moronic enthusiasm for saving the buck).  I just went through
two clean/align cycles and I've still got banding all over the place.
I don't know...surely these must work for some people that they sell
them to.  They can't be surviving with no repeat business at all!
Now I've got to wast good Epson ink switching back and see how much
of this useless stuff they'll give me my money back on.
Stay tuned for the customer service part of our show....
at
affect
so
> Back on topic....
seems
> right on.
> they'd be thrilled.
all!
> I
effort
> you
> > > John Nollendorfs
Re: Lord, I am the Idiot of all Idiots!
2007-03-17 by Greg
One, two, Freddy's coming for you.
Three, four, better lock your door.
Five, six, grab your crucifix.
Seven, eight, gonna stay up late.
Nine, ten, never sleep againÂ….
So, they are blaming the problems on air bubbles... if you have a
syringe you can draw out a little ink from the cart and leave a drop
where the cart goes onto the printhead. That should eliminate the
question of bubbles (though it is odd that the problem goes away as
soon as you switch to Epson carts).
2007-03-17 by Steve
Along the way, two of the little caps on the carts fell off and in to
my printer.  I had quite a time fishing them out.
I didn't reallize what had happened at first and all the yellow ink
ran out of that cart.  Fortunately, they were in a plastic bag.
2007-03-18 by Steven Karafyllakis
OK, now I feel guilty-I've been running an 1800 with MIS inks for
over a year, I should've put in my 2 cents worth, but you jumped on
the Generations rather fast while I was distracted....so anyway, let
me offer you some options.
First, if money is an issue, the MIS Pro inks are probably your best
alternative. They do quite well in color, and on many RC papers
bronze less than the Epsons. The saturation isn't as good as Epson,
but not by a whopping 20%, more like five percent. Close enough
thatyou can make up the difference with a custom profile and a little
tweaking, or even just upping your sat a little.
Do you want good B&W? I'll assume the answer is yes, or you wouldn't
be on this forum. Your choices are:
A) Color Profiles. Get profiling software and hardware and make your
own profiles, (the 'canned' ones will not be good enough) OR, have
custom profiles made for each paper/ink/resolution setting you want
to use. $500 the first way and quite a bit of learning, $40-60 per
profile and a minimum of a week's delay the second way.
B)Download and figure out QTR. There are not many R1800 profiles
supplied for this printer, but the 3 for matte paper will give you a
starting point. From there you can build more BO profiles for your
papers, which works well if the printer is not visibly banding.
If you print color on luster and semi-matte, and think you can live
without glossy papers, you can put an Epson K3 LK or MIS K4 LK cart
in the Gloss position (obviously you'll have to swap chips) and build
your curves with two blacks for RC and 3 blacks for matte papers. The
later approach uses MK properly, but adds the PK between MK and LK.
This gives you smoother shadows, and distributes the use-pattern a
bit better, saving you from having to refill the LK(gloss) as often.
The whole business of swapping LK for gloss works even better with
MIS inks because they gloss a bit less, and therefore need the
optimizer for fewer papers.
If you decide later you're willing to dedicate this printer to color,
you can add more grays-I'm currently using the MIS K4 inks for MK,
PK, LK and LLK and MIS pro in the remaining color positions. I'm
getting results that are indisinguishable from my 3800 and ABW
without a 10x lupe.
If you do decide to go with QTR, contact me off-list later, and I'll
see if I have any profiles appropriate for your ink configuration,
and further suggestions.
Best,
Steve Karafyllakis
http://www.stevekphoto.com
to
drop
as
2007-03-18 by Steve
I jumped on the generations so quickly, because I did not want to
calibarate my digital negative process to epson inks, then switch to
aftermarket inks later (to save money) and have to rework my
process.  Better, I thought, to start out with the less expensive
inks from the start.
The lower saturation really would not have been a problem for my
negatives, because whatever the saturation, I'd adjust the negatives
based on my final results.
I think I'm going to back off of the aftermarket inks for awhile.
My primary use of this printer is for digital negatives.  I need to
get that working with the stock color inks and then I'll worry about
a dedicated black and white system in the future.
Playing around like this has distracted me from my actual goals and
I've accomplished nothing in their direction.
I think that in the end, the problem will be for me to find a good
system for digital negatives that can also print quality black and
white...so I don't have to go switching back and forth.
A second printer might be the best solution when the time comes.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
let
best
little
wouldn't
your
a
build
The
color,
> without a 10x lupe.
I'll
> Best,
> Steve Karafyllakis
2007-03-19 by Steven Karafyllakis
to
Sorry, I didn't mean my remark as a criticism, it's just that very
few people on this list use the Generations inks, so we have no real
help to offer.
>  I need to
about
I don't know how much of this you've done so far, and what processes
you use the negs for, but I feel I must comnplicate your life a bit
more: many processes, if not all, are sensetive to the color of light
you're exposing with. Ergo, if you make a neg with color inks, each
set of dot colors will register differently on the paper. This can
often produce a much 'grainier' print than you would expect looking
at the negative. My take after repeatedly trying to produce silver-
gel quality negs, is that the best solution is to use QTR to mix two
curves: one 3K curve composed of PK, LK, and LLK, and a second curve
composed of magenta, yellow and LLK, or magenta, red and yellow. The
primary work would be done by the gray curve, with the color curve
adding density or in the case of VC papers, contrast, where and when
needed. But again, everything depends on your process and its
spectral response.
At any rate, best of luck, and keep us posted on your progress. One
of these days I'll take another whack at it myself, seeing as how I
have a fair quantity of (free!) Sihl film I need to test.
Steve Karafyllakis
2007-03-19 by Steve
I didn't take offense Steve, or even think you were being critical.
I tend to jump big when I go, and I don't always look first.
I make digital negatives for cyanotypes...so I think I'm a bit
covered by the limited capabilities of that process.  I may move on
to do van dykes in the future, but I don't have any plans for the
higher end processes.
I actually like the very basic alternative processes.  I find it a
nice contrast to the "perfection" of silver/platinum etc...  Which is
just as well since I don't think I have the attention to detail to
really excel at those more demanding processes.
Link to one of my cyanotypes...
http://www.flickr.com/photos/stevemphoto/347434952/in/set-
72157594360326487/
Thanks for your input and willingness to help.
> to
real
> help to offer.
> >  I need to
> about
processes
light
two
The
when
> spectral response.
> Regards,
> Steve Karafyllakis
