Newbie Printer Question
2007-03-18 by Derek Hamlet
I have just about decided to close down my chemical darkroom at least
for a while. I have actually taken the batteries out of my N90X and
it will sit quietly in the closet with only a mild whimper every once
in a while.
I'd love to have a high end epson for printing, but I think that in
order to see how much I like digital printing versus chemical I
should start more modestly.
Paul R. amongst others has suggested that an Epson C88+ is not a bad
place to start.
They are also cheap as dirt right now so that is not a bad place to start.
I little advice is I may ask.
So I have the printer and have not opened the box.
It comes with cartridges, but I'm thinking that since this will be
dedicated to B&W, it is not worth it to pump any of the color stuff
through the lines?
What say you?
I have read Paul's webpages on the C88.  A lot of it I will not
really understand until I actually work through it, however, that
leads me to my second question.
I would like to be able to buy cartridges and refill them myself.
Can someone please recommend what I should buy as a starting point?
cartridges, inks, quantities, nifty little tools that enable me to
refill ink cartridges etc.
Please correctly I assume that I am such a digital newbie that the
obvious may not be so obvious.
Thank You.
;-)Derek
RE: [Digital BW] Newbie Printer Question
2007-03-18 by Gary W. Weaver
Hi Derek,
Much revolves around what paper you use.
You might call Ink Supply and ask about the best combo.
Paper is as important as it is in the darkroom, so tell us what you want
your prints to mimic - real glossy - Portriga, what???
gar
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com]On Behalf Of Derek
Hamlet
Sent: Sunday, March 18, 2007 9:34 AM
Subject: [Digital BW] Newbie Printer Question
in a while.
place to start.
through the lines?
What say you?
Thank You.
;-)Derek
they are often being updated.
page.
them short.
membership without notice.
the membership.
Moderators. See \ufffdGroup Topic, Rules and Guidelines\ufffd in the Files section:
YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE  \ufffdOWNER\ufffd AND
\ufffdMODERATORS\ufffd OF DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE
Yahoo! Groups Links
Re: Newbie Printer Question
2007-03-18 by Roger
through the lines?
Sell the inks on Ebay.
Try inksupply.com for the details and if the main pages don't have
enough info, try the forums.  MIS tech support can also assist you and
confirm what you need.
2007-03-18 by Mike Johnston
With the two Epson's I have purchased (C86 C88)
My son sold the cartridge sets on Ebay.
As a beginner myself I would recommend the MIS ink sets.
You might start with a set of 4 pre-filled cartridges to see if you like
the results.
Mike J.
Hamlet
Sent: Sunday, March 18, 2007 10:34 AM
in a while.
place to start.
through the lines?
What say you?
Thank You.
;-)Derek
The Kirkland paper from Costco is cheap and works very well if you
want to try glossy.
Mike J.
Hamlet
in a while.
place to start.
through the lines?
What say you?
Thank You.
;-)Derek
RE: [Digital BW] Newbie Printer Question - C88
2007-03-19 by Paul Roark
>I'd love to have a high end epson for printing, but ...
> an Epson C88+ is not a bad place to start.
>They are also cheap as dirt ...
And most can't see the difference between a C88 print and those of the most
expensive printers.
>this will be dedicated to B&W, it is not worth it to
>pump any of the color stuff through the lines?
I'd keep the OEM carts until I knew the printer was working right.
The ones MIS sells pre-filled can be re-filled.  So, I'd start with the
pre-filled carts to eliminate that variable and get started sooner.  Then
buy the bulk ink in 4 oz. bottles.  The midtone inks in the "color"
positions are all the same density.  There is warm (pure carbon) and
"neutral" (a bit cool on most papers).  For a more neutral print, I use warm
in the yellow position and neutral in the C and M positions.  So, when you
get to the bulk buying stage, at most you'll need only 2 bottles of the
midtone inks -- warm and neutral.  However, to start you'll need the carts
that have the right chips on them.  So, buy at least one each of the C, M
and Y position inks.
See http://www.inksupply.com/utez.cfm?setMediaCookie=1&the_media_linkID=33
What black to use depends on the paper type: matte paper requires Eboni for
good blacks, and glossy papers require "photo black."  You can switch these
carts as needed.  I'd buy both an Eboni and PK.
When you get to re-filling, you'll need a couple of 10 cc syringes, needles,
and a chip re-setter.  See the MIS accessories page at
http://www.inksupply.com/accessory.cfm
When you fill a new cartridge, an air bubble stays near the outlet.  A
bottom-fill adapter is used to pull this out.
At the end of my page on the C86-88, I have some information on re-filling.
Be sure to get good paper, including some that have settings noted in my
page.  Epson Enhance Matte is cheap and easy.  I don't recommend it for
important prints, but for learning and for proofing it's a good paper.
Hahnemuhle Photo Rag is traditionally considered the best matte paper.  So,
be sure to try some of this.
The excellent cheap glossy paper from Costco appears to be out of stock at
Costco.  MIS and stores may still have some.
Have fun.
