Printing on museo silver rag
2007-04-07 by terrygydesen
I have the Epson 2400 printer currently loaded with Matte black.  Does anyone have a good
method for switching back and forth between Matte black and Photo black?  Do I need to do
anything special when I load in the PK?  Will my cartridge of MK still be ok to use?
Re: [Digital BW] Printing on museo silver rag
2007-04-07 by Dana H. Myers
I just follow the directions; press the ink change button, swap the MK/PK, and
press the ink change button.  Note that this uses up a fair bit of ink, so I
don't do it often.
Dana
2007-04-07 by CDTobie@aol.com
In a message dated 4/7/07 6:21:06 PM, terrygydesen@... writes:
> anyone have a good
Nothing special needed, except a bit of patience with the driver, as it takes
it some time to recognize the changeover, and can offer the wrong media list,
requiring some poking and prodding to get it to realize you've changed
inks...
>   Do I need to do
> to use?
Nothing special needed there either. The more compulsive wash the ink outlet
with distilled water and seal the cart in an airtight ziplock bag. The slobs
just toss it on the counter next the printer, until they need to switch back.
Considering how well the slob technique works, I have a hard time recommending
the compulsive technique... <G>
C. David Tobie
Product Technology Manager
ColorVision Business Division
DataColor Inc.
CDTobie@colorvision.com
www.colorvision.com
 See what's free at http://www.aol.com.
2007-04-08 by john794552
Terry,
If, after changing from Matte black to Photo Black, or vice versa,
you go to Page Setup, Properties, Maintenance, Printer and Option
information, you then can choose your cartridge option, which will
force the correct range of paper options. Better than waiting for it
to happen by switching printer off and on, or by repeatedly trying to
access the correct range of papers, until the drivers decide to kick
in!!
John
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, CDTobie@...
Does
> > anyone have a good
black?
as it takes
media list,
changed
> inks...
> >   Do I need to do
still be ok
> > to use?
ink outlet
The slobs
switch back.
recommending
> C. David Tobie
> DataColor Inc.
> CDTobie@...
> www.colorvision.com
