Soft proofing images in Photoshop
2007-04-16 by alan9990_6
Can someone please explain something to me - I've either set up incorrectly or I'm failing to understand something. This is, I believe, a more general black and white question even though I have also posted on the QTR group: I have my Epson 1290 set up with QTR and am happy with the standard paper profiles for the time being. I've printed out a couple of images using the curves. I wasn't using any soft proofing - just looking at the curves and the resulting images. So when I did decide to set up the proofing profile in Photoshop, I used the supplied QTR grayscale profile and also enabled two switches: 'Preserve numbers' and 'simulate black ink'. It is this last step that has me a little baffled. With the black ink simulation enabled, the monitor does indeed very closely resemble the printed image. But this image seems to have 'muted' deep blacks - it looks like a kind of compression in the very dark tones. If I uncheck the ink simulation in the proofing profile, of course I can see more 'depth' to the blacks. However, since the point of the profile is to simluate the output, I leave it checked. However, if I take the same image in Photoshop and use Paul Roark's curves, and the grey gamma space for soft proofing, I get these same deep blacks both shown on the soft proofing as well as getting a much richer output. I'm not talking here about the differences between matt and pearl or gloss paper - I'm curious to know why I cannot produce as deep blacks with the RIP as I can with Photoshop curves. I don't like not having any proofing available on screen so don't want to use the curves workflow if I can help it. Is there something I've missed or misunderstood?
