R800-1800
R800-1800
2007-04-30 by Paul Roark
If a grayscale image or an image file with R=G=B is fed into an R800, is any
of the Red or Blue used to generate the print?
I assume the C, M and Y are used, but I'm just not sure about the extra
colors.
Re: [Digital BW] R800-1800
2007-04-30 by CDTobie@aol.com
is any
The R800 creates all its grays (except for the very darkest of them,
which incorporate black) from color inks, since it has no gray inks. As
best I can determine it integrates only the Blue into its base
generations scheme, while holding the red out for saturated reds only.
So printing only neutral images should use up CMYB and K inks, but no
Red, except for that used in cleaning. Or course they would be poor
grayscale prints, in terms of consistant neutrality under differing
light sources...
C. David Tobie
Product Technology Manager
ColorVision, Inc.
CDTobie@...
www.colorvision.com
________________________________________________________________________
AOL now offers free email to everyone.  Find out more about what's free
from AOL at AOL.com.
Re: R800-1800
2007-05-01 by Keith Zimmerman
From my experience printing, or rather, attempting to print BW with
an R800, I believe the red and blue inks are used.  At least that is
what I suspicion happens.  I never made any color prints on the
printer and the red and blue carts ran out of ink just as fast as
the others.  I don't think it was just cleaning cycles that used all
the red and blue because I always had my printer powered on except
when I was traveling.
FWIW, I never got a single decent BW print from the printer so I
sold it to someone that prints only color.  He loves it.
keithz
R800, is any
extra
> colors.
> Thanks,
> Paul
RE : [Digital BW] Re: R800-1800
2007-05-06 by Jean Claude Parent
hello,
  I'm owner of an R1800 (same driver etc  as R800) and with specific's curves made wirg QTR I finally succed by having quite good (at least for me ;-)  ) BW prints WITHOUT any other colors
  I Check it under big magnification with binocular on the neutral curves I did . of course with the warm curves or sepia I added very few yellow or red...
  the R1800 /R800 have B&W abilities only with QTR , I never succed before using this RIP to get real B&W prints - it was allaways some "greenish" or other colors on certain grays (green closed to 40% and magenta around 70% gray scale)
  Check on the files and try the curves !!!
  BTW please give me your comments,
  bye from France
keithz
R800, is any
extra
> colors.
> Thanks,
> Paul
BTW Have nice prints with QTR
don't forget  "Life is just what we are looking for..."
R1800 mostly in B&W (80%)
Lyson Inks R8
Moab papers
JCP
 Découvrez une nouvelle façon d'obtenir des réponses à toutes vos questions ! Profitez des connaissances, des opinions et des expériences des internautes sur Yahoo! Questions/Réponses.
2007-05-07 by jfree2hear
Can you point where are the files and curves? I couldn't find them...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Jean Claude
Parent <jcpeos@...> wrote:
> hello,
>   bye from France
print BW with
> keithz
> R800, is any
> extra
> > colors.
> > Thanks,
> > Paul
> Lyson Inks R8
> Moab papers
> JCP
R800-1800 pure carbon printing
2007-05-07 by Paul Roark
Since there are several others experimenting with similar approaches, I
thought it appropriate to share some initial results I'm having with the
R800-1800. Although the first R800 refurb I purchased was defective, I saw
encouraging enough results to buy an R1800 (which just showed up while
writing this).
The bottom line for me is that "pure, 100% carbon" (plus base, etc., of
course), "neutral" (essentially paper white to relatively neutral black)
printing at what I consider photo quality may finally be possible.  I'm
using multiple MIS Eboni jets and the Epson driver.
For the approximate spectral Lab A & B distributions of Eboni, see:
http://www.paulroark.com/BW-Info/Eboni-PA-325-BO.jpg for Premier Art Smooth
(Hot Press) 325 (no OBAs), and
http://www.paulroark.com/BW-Info/Eboni-PA-MBW-BO.jpg for the very affordable
and bright Premier Art Matte BW.
For a comparison of the 5% patch of an Epson k3 Advanced B&W mode print to a
similar density patch printed with 5 Eboni jets firing in an R800, see:
http://www.paulroark.com/BW-Info/800-5-Eboni-v-2400-ABW-1600dpi.jpg
(The defective R800 may not have been firing all 5 jets.)
Whereas "Black Only" printing with the 3.5 picoliter printers was sometimes
referred to as "Digital Tri-X," the R800/1800 might be referred to as
digital Tmax 100.  The link below is to a rather crude "apples v. oranges"
comparison of (1) a light midtone test patch of a Tmax 100 negative scanned
at 4000 dpi with my Nikon 8000 to (2) an R800 print, similar density test
patch scanned on an Epson 1600 flatbed at 1600.  The Epson scan was then
downsized so that it would at least mathematically be at the same
magnification as the medium format Tmax 100 scan if such had been enlarged
to an 8 x 10 print.  The image you'll be looking at would be 1.2 x 1.7 mm on
an 8x10.  (The Tmax patch arguably needs to be sharpened to bit.)
http://www.paulroark.com/BW-Info/Tmax-R800-8x10.jpg
Note that I am not doing "Black Only" printing in the sense that it's been
used previously.  I have multiple Eboni carts in the midtone spots.  This is
definitely a dedicated B&W approach, not something someone would do to also
be able to print color with the printer.  Most single-jet BO prints have
simply been too rough for my tastes.  I'm aiming to match the quality of my
medium format Tmax 100 prints.
The workflow tentatively would be to simply print a grayscale file with the
Epson drive, using an ICC in the print preview.
To make the ICC, a 21-step test file is first used to determine the best
dmax.  Then a curve from (0, 0) to (100, [best dmax point]) is made.  I'll
probably have a 50% point pulled down to get approximately the right density
distribution.  A second test strip is printed with this Photoshop curve.  It
has its Lab L values read for purposes of linearization.  Then the curve and
the text file with the L or density values are dropped into Create ICC-RGB
to make the ICC.
The bottom line is that the Epson driver would be used, and the system would
be able to be linearized even with a flatbed scanner.
The idea is to achieve pure carbon printing, with no color inks to cause
green shifts, etc.  There are no cross-overs or partitioning to worry about.
The monitor and print will be matched via Create ICC.
There are obviously many modifications one could do to this approach.  LK
could be used to warm up prints or smooth the highlights on brightened
paper.  I have not explored whether there is a neutral PK that might also be
incorporated.  Eboni's neutrality is obviously key to this approach being
acceptable to me.  Dilute carbon inks are too warm for me.
My hopes are that this will make the most lightfast digital prints possible
in a manner that is so simple old darkroom types will be able to relate to
it without ever having to learn anything about how partition curves, control
the tones of prints, or much else.
This is not going to be for everyone.  The prints do show a very fine grain.
But then those of us who've worked with film don't mind that, in fact, it
can lend a sense of sharpness to an image.  But, as noted above, Tmax 100 in
medium format was my standard for years.  I aim to match that quality level,
at least.
As a side benefit, consider what this does to your ink costs.  You don't
need much Eboni to make prints.  It's the diluted inks that drive up the
costs.  Light inks are expensive water.  Then there is the simplicity of
filling multiple carts with the same bottle of Eboni and single syringe.
("UC base" [no binder] may be in the other spots to help keep the sponges
and heads clean.)
This is still in a development stage.  So, my results are tentative, and I
definitely reserve the right to change my opinion and dump this approach.
However, right now, I'm very excited by the prospects of a simple, neutral,
pure carbon, photo quality printing approach.  I think it will be something
old darkroom printers can live with very nicely.  (I wish there were a 24
inch printer with 1.5 pl dots.)
RE: [Digital BW] R800-1800 pure carbon printing
2007-05-08 by Paul Roark
In the new 1800 (also a defective machine, but better than the refurbished
800), I'm getting slightly warmer results than in the 3.5 pl printers.  The
Premier Art Matte BW and Smooth 325 are hitting a peak warmth at about 70%
of almost Lab B 2 and 2.4, respectively.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Paul
Roark
Sent: Monday, May 07, 2007 3:04 PM
Subject: [Digital BW] R800-1800 pure carbon printing
writing this).
http://www.paulroar <http://www.paulroark.com/BW-Info/Eboni-PA-325-BO.jpg>
http://www.paulroar <http://www.paulroark.com/BW-Info/Eboni-PA-MBW-BO.jpg>
http://www.paulroar
<http://www.paulroark.com/BW-Info/800-5-Eboni-v-2400-ABW-1600dpi.jpg>
http://www.paulroar <http://www.paulroark.com/BW-Info/Tmax-R800-8x10.jpg>
to make the ICC.
at least.
and heads clean.)
Re: [Digital BW] R800-1800 pure carbon printing
2007-05-08 by Carl Schofield
Paul,
Sounds like a promising approach.  Did you try this with any of the
3.5 pl printers and is there any improvement relative to single
channel BO printing or do we need the smaller 1.5 pl dot size for the
highlight/midtones to minimize "grain"?  Also, do the "1.5 pl"
printers only use the smallest dot size in the highlights (assuming
they use some kind of variable dot size approach) or is this
controlled by driver resolution settings?
Carl
> refurbished
> printers.  The
> about 70%
> Paul
>   _____
> Paul
> Roark
> approaches, I
> with the
> defective, I saw
> writing this).
> etc., of
> black)
> BO.jpg>
> BO.jpg>
> print to a
> see:
> http://www.paulroar
> sometimes
> oranges"
> scanned
> density test
> then
> enlarged
> 1.7 mm on
> R800-8x10.jpg>
> it's been
> This is
> to also
> have
> quality of my
> with the
> best
> I'll
> right density
> curve. It
> curve and
> ICC-RGB
> to make the ICC.
> system would
> cause
> worry about.
> approach. LK
> also be
> being
> possible
> relate to
> curves, control
> fine grain.
> fact, it
> Tmax 100 in
> quality level,
> at least.
> don't
> the
> syringe.
> sponges
> and heads clean.)
> and I
> approach.
> neutral,
> something
> a 24
> Paul
> www.PaulRoark.com
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier messages
> to keep them short.
> flames. Hostile, aggressive or argumentative users may be removed
> from the membership without notice.
> - Keep your posts and threads related to the group topic of digital
> B&W printing. Users who persistently make off-topic posts may be
> removed from the membership.
> - By posting on this forum you agree to abide by the group rules
> and guidelines, and to abide by the actions and decisions of the
> group Owner and Moderators. See “Group Topic, Rules and Guidelines”
> in the Files section:
> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE
> PRINT YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
> “OWNER” AND “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL
> NOT BE LIABLE TO YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> CONSEQUENTIAL OR EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO,
> DAMAGES FOR LOSS OF PROFITS, GOODWILL, USE, DATA OR OTHER
> INTANGIBLE LOSSES (EVEN IF THE  “OWNER” AND “MODERATORS” OF DIGITAL
> BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
> SUCH DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE
> THE DIGITAL BW, THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO
> OR ALTERATION OF YOUR TRANSMISSIONS OR DATA; (iii) STATEMENTS OR
> CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE PRINT YAHOO
> GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW, THE
> PRINT YAHOO GROUP.
Hi Carl,
I really like the idea of no color pigments, and the tones I'm getting on
Premier Art 325 (no OBAs) is just a bit warm, but looks fine to me.
I'm now printing with QTR and 3 jets.  It may be enough to reduce the
typical one-jet banding sufficiently.  If so, it would allow the 1800 to be
a full Epson driver color printer as well as a pure carbon QTR printer if
only matte paper was used.
>  Did you try this with any of the 3.5 pl printers
Not yet.  The single channel 3.5 pl BO is a bit rough, but it is worth a try
on one of them also.
> ... do the "1.5 pl" printers only use the smallest dot size
> in the highlights (assuming they use some kind of variable
I'm not sure.  I've been using the highest resolution so far, assuming that
is going to be needed.  The 1800 is fast enough that the high resolution
settings are fine.
With QTR (and maybe even with the Epson driver) it may be that staggering
the curves is needed to control some artifacts.  The Gimp ordered dither is
not particularly good with this setup when all are on the same curve.  Once
the curves are varied, the "ordered" nature of the pattern is more
scattered.  The highlights still seem a bit too ordered, but I'm not sure
anyone can see that without a loupe.
It's still early in this experimenting, and unfortunately, I'm at a
disadvantage due to these defective refurbs.  The C,M & Y jets are working
on this one, so I'm a bit more able to see what a good printer will look
like.
Paul,
The Epson 4000 driver dither is already quite good with just single
channel BO so it might be a good candidate for multiple Eboni
channels.  Does the GRAY_OVERLAP function in QTR help at all with
smoothing out the banding artifacts in the 1800?
Carl
On May 8, 2007, at 3:05 PM, Paul Roark wrote:
> Hi Carl,
> getting on
> 1800 to be
> printer if
> worth a try
> assuming that
> resolution
> settings are fine.
> staggering
> dither is
> curve.  Once
> not sure
> working
> look
> like.
> Paul
> www.PaulRoark.com
2007-05-09 by Jean Claude Parent
here is the link to the files:
  http://tech.groups.yahoo.com/group/QuadtoneRIP/files/Curves/R800%20and%20R1800/
  have fun
  bye
> hello,
> bye from France
print BW with
> keithz
> R800, is any
> extra
> > colors.
> > Thanks,
> > Paul
> Lyson Inks R8
> Moab papers
> JCP
Lyson Inks R8
Moab papers
JCP
2007-05-09 by Carl Schofield
Paul,
Sounds very encouraging.  If I can get some empty carts I will do
some experimenting with my wife's R380 printer if Roy has this one on
his list.  I use MIS PK in my 4000 and 2400 and it is very warm as a
BO print.  PKN give a neutral/cool BO print.
Carl
On May 9, 2007, at 12:15 PM, Paul Roark wrote:
> Hi Carl,
>> with just single channel BO so it might be a good
>> candidate for multiple Eboni channels.
> I've been testing my 2200 with multiple Eboni ink channels as well
> as the
> 1800.  In general, the multiple channels can greatly reduce or
> virtually
> eliminate microbanding, but it does not smooth out the grainy 2200
> midtones.
> So, the graininess you see with BO is probably what you'll get with
> multiple
> Eboni channels.  The larger dots to print slightly more neutral,
> which I'd
> say is an advantage.  However, the 1800 Eboni prints on non-brightened
> Premier Art Smooth (Hot Press) 325 are definitely a tone I can live
> with --
> just slightly warm.
> The very light tones are actually better with a single channel
> firing.  I'm
> getting close to "perfect" 1800 images (with a barely visible fine
> grain
> structure) by having a single jet fire to 25%, another one start
> there,
> another at 50%, and another at 75%.
> How many channels are optimum is still an open question.  From what
> I've
> seen 3 may be a bit too little, and more than 4 may not result in any
> visible improvement.  Whether the extra 1800 channels are useful is
> an open
> question.  So far I'd say that as soon as Roy gets the new 260 and
> 1400
> going, they'll make good candidates for this approach.
> Have you done a BO print with Epson PK?  I'm wondering how neutral
> it is.
> I'm using QTR for this, with curves simply entered in the point
> lists.  The
> channels are not partitioned, since they are all the same density.
> The inks
> never go into a negative slope.  Right now most curves are essentially
> straight lines, with the caveat that I make the starting points of
> all but
> the first one more gradual than a straight line would be.  The last
> curve,
> which carries much or the black, has a highly increasing slope.  I'll
> probably come up with a more or less overall slope and then figure
> out how
> to make the system more simple and equalize ink usage somewhat.
> Right now I
> have not figured the areas under the curves.
> I'll be sending this defective 1800 back soon, but, again, I think
> for those
> interested in a pure carbon print that will not suffer from the
> inevitable
> differential fade of the magenta & cyan color pigments, it
> tentatively looks
> like a viable solution for up to 13 x 19.
> Paul
> www.PaulRoark.com
2007-05-09 by Paul Roark
Hi Carl,
I've been testing my 2200 with multiple Eboni ink channels as well as the
1800.  In general, the multiple channels can greatly reduce or virtually
eliminate microbanding, but it does not smooth out the grainy 2200 midtones.
So, the graininess you see with BO is probably what you'll get with multiple
Eboni channels.  The larger dots to print slightly more neutral, which I'd
Premier Art Smooth (Hot Press) 325 are definitely a tone I can live with --
just slightly warm.
The very light tones are actually better with a single channel firing.  I'm
getting close to "perfect" 1800 images (with a barely visible fine grain
structure) by having a single jet fire to 25%, another one start there,
How many channels are optimum is still an open question.  From what I've
visible improvement.  Whether the extra 1800 channels are useful is an open
question.  So far I'd say that as soon as Roy gets the new 260 and 1400
Have you done a BO print with Epson PK?  I'm wondering how neutral it is.
I'm using QTR for this, with curves simply entered in the point lists.  The
channels are not partitioned, since they are all the same density.  The inks
straight lines, with the caveat that I make the starting points of all but
the first one more gradual than a straight line would be.  The last curve,
probably come up with a more or less overall slope and then figure out how
to make the system more simple and equalize ink usage somewhat.  Right now I
I'll be sending this defective 1800 back soon, but, again, I think for those
interested in a pure carbon print that will not suffer from the inevitable
differential fade of the magenta & cyan color pigments, it tentatively looks
PKN is also loaded with C & M, which defeats most of what I'm after.  For
snaps and postcards, however, it may be a way to utilize the extra jets.
  _____
[mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf Of Carl
Schofield
Sent: Wednesday, May 09, 2007 7:25 AM
Subject: Re: [Digital BW] R800-1800 pure carbon printing
Paul,
Carl
> Hi Carl,
> as the
> virtually
> midtones.
> multiple
> which I'd
> with --
> just slightly warm.
> firing. I'm
> grain
> there,
> I've
> an open
> 1400
> it is.
> lists. The
> The inks
> all but
> curve,
> out how
> Right now I
> for those
> inevitable
> tentatively looks
> Paul
> www.PaulRoark.com
RE : RE: [Digital BW] R800-1800 pure carbon printing
Paul and Carl,
  I am following your test & trials... very exiting !!!
  Do you believe You'll succeed by keeping the color printing of the R1800 and giving us the way to print good B&W?
  Are you testing with the PK and BK and  with the Gloss head ? why not...? meaning three blacks... QTR is right for that...
  Does the Gloss head have the same dot size? If yes, I could live without any Gloss on my Color prints... it's possible to print on "Pearl" paper type without any gloss...
  thks for your efforts and good luck, I am waiting and confident...
  BTW a shake hand from Paris
_____
Schofield
Paul,
Carl
> Hi Carl,
> as the
> virtually
> midtones.
> multiple
> which I'd
> with --
> just slightly warm.
> firing. I'm
> grain
> there,
> I've
> an open
> 1400
> it is.
> lists. The
> The inks
> all but
> curve,
> out how
> Right now I
> for those
> inevitable
> tentatively looks
> Paul
> www.PaulRoark.com
Lyson Inks R8
Moab papers
JCP
RE: RE: [Digital BW] R800-1800 pure carbon printing
Hi Jean Claude,
Let's hope 1.5 pl dots allows us to finally get rid of the color pigs
totally in relatively neutral, photo quality prints.  I do still see a few
occasional artifacts in my test prints, but I'm hopeful.  Don't bet the farm
on it yet.
With the 1800 I now have (a defective refurb that I'm going to return) the
issue is microbanding.  Can it do a 3-Eboni B&W without microbanding?  I
can't say for sure. If it can, then matte color and pure carbon would be
possible.
>Are you testing with the PK and BK and with the Gloss head?
I'm installing PK & Glop now.
2007-05-10 by Paul Roark
It looks like, with some caveats, the R800/1800 can print both color and
100% Carbon/Eboni B&W -- on matte paper.  The Glop channel prints just like
the others.  Also, 3 good channels can produce an excellent print.  So, one
could print color with the Epson driver and have Eboni in the MK, PK, and
Glop spots and use QTR to print pure carbon B&W.
The caveat is that not all of my channels are perfect.  Three good channels
-- meaning only minor microbanding when printed by themselves -- can make an
excellent print.  If one of the 3 needed for the carbon printing was a bad
channel, I'm not sure you'd have enough jets firing to cover the defects.
>Are you testing with the PK ...?
The Epson R800 PK is too warm and green.  Really ugly as a BO print, but a
great, high gloss dmax.  Without glop covering it on Kirkland glossy paper
the reflection makes about the strongest rainbow I've seen.
Actually, I think Eboni covered with glop on something like the Innova semi
matte might be more interesting.  Frankly, I'm still a matte paper printer
and will probably not pursue this much.  I did try some Eboni on Kirkland
with glop.  The glop might nail down the Eboni enough at least through the
midtones.  With an appropriate PK and on an appropriate paper, it could be
part of an interesting medium warm print solution.
2007-05-10 by jcpeos
thanks Paul for all these answers...
As I am printing with Lyson inkset for the R1800, I'll have to change
all my stuff to come on the MIS inkset... the Lyson and the MIS are
not compatible ??? but I have to believe the one who knows ;-)
I will change the carts by new one and flush all my Continuous Ink
System (bottles, tubing)
I'll flush with a ink solvent and cleaning cartridge to flush the
head before going to MIS inks with -SURE - the 3 channels BK your are
testing !!!
I am so confident on your success
go ahead, the r1800/r800 owner will look on you as the King..
Jean Claude
color and
just like
So, one
PK, and
channels
can make an
was a bad
defects.
print, but a
glossy paper
Innova semi
printer
Kirkland
through the
could be
> Paul
> www.PaulRoark.com
R800-1800 Eboni Carbon Core variations -- Neutralizing with R800 Blue
2007-05-11 by Paul Roark
This is my latest experiment with this un-diluted, relatively neutral Eboni
carbon core and the R1800.
Since the Eboni core is more neutral to start with than the other neutral,
non-blended carbon pigment inks, it might make an interesting starting place
for the relatively neutral tonal (color) space I tend to like to print in.
The more neutral the starting carbon core, the less color inks need to be
added to achieve even a more neutral print.  The fewer the color inks, the
better I like it.
With the previous variable tone inksets, to offset a yellowish carbon, I
used a blue toner.  I started mixing the blue toners from cyan and magenta.
Then, when R800 blue became available, I used it and cyan.  To avoid the
problems of blended inksets, I moved to separate LC and LM channels.  One
problem I have with this approach is that the cyan and magenta will fade at
different rates.  Most likely, the prints will shift green as the magenta
fades faster than the cyan.  (Compare the RIT magenta and cyan pigment fade
rates for MIS older color pigments at http://www.inksupply.com/rit.cfm  Over
about a 50 year simulated display life, the cyan was 5 to 7 times more
lightfast.  This strong cyan pulls the image tone into green as the magenta
fades.)
The first interesting toning variation to the multiple channel Eboni
printing I've been experimenting with on the 1800 is to use a bit of R800
blue as a single-color toner.  Basically, a tiny amount of R800 Blue makes a
more neutral, classic "selenium" looking print.  What I did is equalize the
maximum midtone (50%) values for Lab A and B.
See the charts at http://www.paulroark.com/BW-Info/Eboni-Blue-PA270.jpg
These compare the spectral distributions of Lab A and Lab b.  (On the graph,
the paper white is on the left and the 100% black on the right.)  The top
chart is 100% Eboni.  The bottom chart is a QTR profile that injects just
enough R800 blue into the Eboni core to make Lab A = B = 2 at 50%.
This lowers the total chroma from 3.7 to 3.0 (according to my X-Rite
Spectro) and, to me, makes a print that I might favor in some situations.
The amount of toning can be varied via the ink limit and sliders in the QTR
and IJC.
The total amount of R800 Blue ink needed to reach this point in a curve
point at 50% of (50, 13), with an ink limit of 2.  So, multiplying these
values, the R800 blue would be at 2.6%.  At this point the Eboni curves
total 9.4%, for comparison (but note that Eboni is probably a higher load
ink).  (The dmax for the carbon curves is at 82%.)   The more neutral curve
prints a 50% Lab L value of about L = 53, whereas the 100% Eboni core curve
at this point prints a 50% Lab L = 53.9.  So, there is little density that
will be lost due to any blue ink fade.
So one gets a slightly more neutral print to start with at the expense of a
slightly larger warm color shift if the print is ever displayed for very
long periods.
RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Neutralizing with R800 Blue
This graph shows the spectral distributions of the Eboni core neutralized
with R800 Blue on brightened Premier Art Matte BW:
http://www.paulroark.com/BW-Info/MBW-1800-EB-N5.jpg
The maximum blue addition is at 80%, where the Lab L density increases from
29.8 for pure Eboni to 29.5 for Eboni plus the blue.  So, if the blue
totally faded, it may be that density would only be decreased by L 0.3.
At 50%, the addition of the blue needed to neutralize the Eboni medium
warmth raises the density by L 0.8.  For comparison, looking at a dilute
carbon inkset and comparing the carbon 50% to the neutralized 50% density
(in Lab L), there is a 3.7 difference.  These numbers are probably
approximate (samples of one each), but I think they help show the
differences I'm trying to achieve.  Assuming the color inks totally fade and
the carbons are equally strong and do not fade (but we know dilute inks tend
to fade more), the Eboni-based neutral print at 50% would fade only 20% as
much as the dilute-carbon based neutral inkset print.  And, of course, with
the single R800 blue ink as the toner, there would be no cyan to pull the
tone into green.  The fade path would be straight from the neutralized to
carbon tones.  The single ink toner is also vastly easier to profile.
  _____
Roark
Sent: Thursday, May 10, 2007 5:43 PM
Subject: [Digital BW] R800-1800 Eboni Carbon Core variations -- Neutralizing
with R800 Blue
better I like it.
<http://www.inksupply.com/rit.cfm> y.com/rit.cfm Over
fades.)
<http://www.paulroark.com/BW-Info/Eboni-Blue-PA270.jpg>
and IJC.
long periods.
www.PaulRoark.com <http://www.paulroar <http://www.paulroark.com/> k.com/>
RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Warming with R800 Red
With just a little red (.52% at 50%) injected over the Eboni core, I'm
getting Lab A=B=2.5 on Premier Art 270.  This is a nice medium warm that is
close to what LensWork uses.  More red causes Lab A to exceed B -- that is,
it starts to go red.
I am now also using an Eboni core that uses only the 3 channels MK, PK, and
Glop.  (It looks the same as the 6 Eboni channel core.)  That allows full
color printing on matte paper.
RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Eboni + OEM color or EZ inks for B&W Gloss printing?
2007-05-12 by Paul Roark
I've worked with numbers of carbon channels from 1 to 6.  There is such a
thing as too many here.  I'd peg 4 as the optimum.  3 Eboni channels prints
better than 6 channels and visually indistinguishable from 4 channels.
Thus, with 8 channels available, the 1800 can support dual channels of
excellent printing.
One option that uses this is full color printing as well as the Eboni 100%
carbon printing.  For those who do full color and also want what is probably
the most stable and lightfast digital B&W system we have, the 1800 is a very
interesting alternative.  In this alternative, all the colors are OEM or MIS
alternatives.  The color prints with the usual Epson driver workflow.  I did
a few color prints and they were excellent.  The Eboni is in the MK, PK, and
Glop channels.  They are controlled by QTR.  Only matte paper can be printed
this way.
A second option that will appeal to those who would rather have a glossy B&W
alternative, the 1800 can support a separate EZ-N or other B&W printing
inkset.   I may put an EZ-N set with PK in my 1800 next (as well as, of
course, the Eboni channels for carbon matte printing).  I want the MIS PK
there to be able to warm the Eboni in any case.
At any rate, this 8-channel, 1.5 pl R800/1800 printing platform appears to
give us the capability of running dual inksets.  I think this is rather
cool.
RE : RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Eboni + OEM color or EZ inks for B&W Gloss printing?
2007-05-14 by Jean Claude Parent
Yeah !!!
  so you got it !!!
  dual abilities "color & Good B&W" for the R1800/800 but as said before , only for Mat papers...
  does a "pearl" surface have a lot of metamerism by printing with the Ebony Black  when one would get a color print on this "pearl" surface?
  If Yes, what about spraying an "gloss agent against UV" to get a "so gloss" apparence?
  Bravo !!
  As I said previously, I'll jump to MIS Ebony If you succeed... so time is coming for me to leave LYSON !
  and
  1)to buy some emptyed MIS cartridge to change mine full of Lyson inks
  2) to flush my printing heads with cleaning fluid
  3) to install the new emptyed cartridges and set up my CIS (after a complete flushing of tanks and tubing system of the Lyson CIS sytem)
  4) enjoy real B&W printing !!!
  rgds
  jean claude
excellent printing.
this way.
cool.
Lyson Inks R8
Moab papers
JCP
 Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail
Paul,
  when do you feel that this new ebony set will be available to buy?
  and what will be it's references?
  thanks & rgds
  jean claude
excellent printing.
this way.
cool.
Lyson Inks R8
Moab papers
JCP
RE: RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Eboni + OEM color or EZ inks for B&W Gloss printing?
2007-05-15 by Paul Roark
Hi Jean Claude,
>... dual abilities "color & Good B&W" for the R1800/800
>"pearl" surface?
I think Eboni on the pearl surface will look dusty -- flat.  I think peal
needs Photo Black, unless I'm thinking of the wrong paper.  Metamerism is
not a problem with Eboni.
Some spray matte black inks on glossy surfaces.  Actaully, in one experiment
I used Glop in the 1800 to nail down the Eboni.  It worked for the lighter
densities, but the high loads from about 85% on continued to be easy to
smear.
(The 260 is next -- no dual capabilities there, just simple, cheap Eboni for
now.)
Jean Claude,
I don't know.  I'm still experimenting with it.  Minimizing the artifacts
with 1.5 pl dots and only high load inks is harder than with very dilute
inks and large dots.  I haven't had the time to see how different papers
look either.  So far my usual un-brightened Premier Art Smooth 270 seems
good, but I'm not sure if it's even available where you are.  Do they sell
Epson UltraSmooth there?
Of course, anyone with an R800 or 1800 can buy Eboni and stick it in several
positions and experiment with this.
RE : RE: RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Eboni +
2007-05-15 by Jean Claude Parent
Paul,
  >Minimizing the artifacts....dilute inks...and large dots.
  Does that means that the Ebony is much more difficult to set with QTR than BK and LK?
  >premier art smooth...
  is available but EPSON UltraSmooth got another name on European market with same (of course) references SO41896 -13*19 it is called here "photo art Fin ultra lisse..."
  >of course every one can buy & test ebony...
  paul, we believe in you !!!
  you are the one able to set and dilute as it should the several blacks so... I (we?) are waiting after your experiences...
  BUT:
  if I could help you in any ways like:
   testing on some papers (moab, Ilford...) but I don't have the correct inks ;-(
   doing some another stuff ?
   or anything else in my possibilities...
  I'll do it with pleasue...
  don't hesitate
  jean claude
Jean Claude,
Lyson Inks R8
Moab papers
JCP
Re: [Digital BW] R800-1800 Eboni Carbon Core variations -- Eboni +
2007-05-15 by jcpeos
Paul,
>Of course, anyone with an R800 or 1800 can buy Eboni ... and
To check the "bad" effect on Color Prints with the BK (from lyson not
MIS)
I did an icc profile for my "semi-gloss" moab KOKOPELLI paper and the
BK ink.
to be sure to print with the BK instead of PK, I printed my "Test IT8
print" with the R1800 driver setting for Matt Archival
I print with Phptoshop CS on this semi matt paper and OFF COURSE got
a lot of Non "semi-glossy" places due to the BK ink...
Easily corrected with a spray and the result is quite correct but not
as perfect compare to a print with PK instead of BK (both icc
profiles for the duo -lyson & moab- are mine done with MonacoEZcolor)
So, my question is:
with your 3 blacks Ebony inks is that possible to use as "mid
black" (dark grey) the PK ink ?
meaning
   BK -Ebony Black-
   + PK
   + LLBK (ebony) in the Glop position
Does that won't fit with your project ?
if the B&W prints result is quite closed to your 3 black Ebony's inks
using QTR, is that a solution for keeping color prints on Glossy/semi-
glossy papers with the Epson driver?
In fact the question is:
Does the PK is compatible wth EBONY's Blacks-normal and/or diluted-?
Sorry for these "new bee" questions?
jean claude
> Jean Claude,
artifacts
dilute
papers
seems
they sell
in several
> Paul
> www.PaulRoark.com
RE: RE: RE: [Digital BW] R800-1800 Eboni Carbon Core variations -- Eboni +
Jean Claude,
How the Eboni curves are set up affects the quality of the image.  My
intention is to come up with a standard set of curves for the Eboni that
minimizes the artifacts, and then most people would simply tweak the dmax
and linearize for different matte papers.  So come up with this initial set
of Eboni curves, however, is a manual trial land error effort to a certain
extent.  The QTR semi-automatic partitioning does not do it, since these are
all the same density.  Also, right now I have the Glop position carrying the
dmax.  I did this because I don't know if there is a simple way to check the
nozzles for that position.  So, I was just going to hide problems in the
deep shadows.  However, not having the black boost makes tweaking the dmax
more difficult, so I might move the dmax control back to MK to utilize the
boost.
Right now 2 of the 3 Eboni curves are just straight lines.  So, I have yet
to do a lot of experimenting with curve shapes.  That fact that I'm getting
creamy-smooth prints at normal viewing distance is encouraging.  Getting
them perfect with a loupe is not there yet, however.
Some of the issues actually remind me of the old 3000, where the paper
transport was barely good enough even in the best of circumstances.  I'm
finding, for example, that the ends of the paper, particularly the bottom 1"
(2.5 cm), are more prone to microbanding.  The 1800 appears to benefit from
having both the main and exit rollers doing their jobs.  So, whereas I'd now
be getting nearly perfect 11 x 14 prints on 13 x 19 paper (which, by the
way, is my target for sale prints -- so I'm there for me), I'd like to see
if I can make more progress with smaller prints.
It may be that thinner paper is needed.  I'll try the 205 today.
(I'm also getting flaking with Premier Art 270.  I've never had flaking with
the 205 or 325.  However, those 2 are dual sided.  I'm wondering if this
flaking is due to a single coating or is an artifact of Eboni.  I doubt it's
the Eboni.)
I'm finding the Premier Art (UltraSmooth) coating to give me the print tones
I like.  The more "edge" there is with the Eboni dots, the more the warmth.
So, more dilute means more warmth.  More small dots are warmer than fewer
large dots.  Papers that hold a tight dot seem to give a more neutral paper
than those that allow the dot to spread.  So, for neutrality, we'd like
perfectly opaque dots with perfectly sharp edges.  The Eboni is dense enough
that the centers of the dots are opaque, but minimizing the spread of the
dot makes a better print, in my view.
I have not tried a large number of papers yet, but the Moab line is clearly
one that may be very suitable for this approach.  I suspect Clayton's
experiences with BO printing and print tone may apply here.
(By the way, with 3.5 pl printers, I get a more neutral print.  To match the
R1800 print tone, I can add just a bit of LK.  This warms the larger prints
so they match the 1.5 pl prints.  It also significantly reduces the
roughness of the print.  Hint: don't throw away old 7600s and 9600s that
have a few clogged jets.  What's left of them may be perfect for making
large prints that match the tone of the small prints people with 260s will
be getting.)
I'll try to keep people posted on my progress, including the weaknesses.
This is not for everyone, but I am hopeful those who want to get the color
inks out of their prints yet still have a neutral-looking, photo-quality
print will be able to use this method to do so.  We'll see.
>as "mid black" (dark grey) the PK ink ?
MIS PK makes a very warm print.  The Epson PK is warm and greenish.  If one
wants color + Eboni B&W in an 1800, then there is no more room for anything
else.
>meaning BK -Ebony Black- + PK + LLBK (ebony) in the Glop position
Recall that diluting leads to warmth.  So, what I'm doing is not using any
dilute black inks.  That's why I can make a relatively neutral print without
color inks (that will cause color -- green -- shift as they fade at
different rates).
One could have a 3-ink, partitioned B&W inkset in the 1800 also.  With this
you'd use the color inks to tone the warm carbon core. The carbon core could
probably be partitioned almost automatically with QTR. This would be the
same as the generic K3 inkset I'm suggesting for the 220 and ALL Epson
hextone or better printers where one wants a variable tone inkset.  This is
easy -- almost too easy to be any fun for me.  One could probably just use
Mk, Pk, and Lk for the matte.  Then the question would be whether just the
LK and PK could make a good glossy B&W print.  The LK might spread enough to
cover the microbanding.  Also, you'd have color inks being poured in to
neutralize the image, so I'd probably be fine for a glossy B&W.  But, of
course, we'd be back to color inks in our B&W prints and all the
complexities of balancing the color inks.  Also, there would be no room for
Glop in this setup, but I use MIS inks for glossy B&W without glop for my
brochures and the like.  They don't bronze very much on many papers.
RE: RE: [Digital BW] R800-1800 Eboni variations -- Arches Un-coated paper
2007-05-16 by Paul Roark
I've always thought that from a "collectible" perspective, pure "carbon on
cotton" might be the ultimate B&W inkjet medium.  With the 1800 firing 3
channels of Eboni onto UN-coated Arches Bright White Hot Press 140 lb. (300
gsm), I think I'm closer to an acceptable photo-quality "pure" carbon on
cotton image than I've seen before.
Usually I consider a 1.60 dmax density (about Lab L 18) to be my minimum
acceptable dmax for matte papers.  I'm happy to say I'm measuring that on
Arches HP now -- at least occasionally.  The blacks deeper than 95% have a
blotchiness to them that causes the measures to vary a bit.  The blotchiness
might be best avoided in smooth, heavily-filtered skies, where 95% would be
the darkest tone that would be very smooth.  On the other hand, in most
situations, the slight un-evenness is probably not a big deal.  At any rate,
with 3 Eboni channels firing, for a total QTR load of about 157, a 1.60 (L
18.06) is possible.
The Lab A & B tones are nearly perfect for this creamy paper.  The paper
base has an (a, b) of (0.7, 2.8).  These reach a maximum at about 50% of
(1.3, 3.6).
See http://www.paulroark.com/BW-Info/ArchesHP.jpg for a graph of Lab A & B.
The un-coated Arches HP is not quite as smooth as Epson UltraSmooth, but
it's not bad.  These dense little Eboni dots don't spread very much.
I'm looking at a test print of my New Army Pass shot, which is on my home
page at www.PaulRoark.com, and it looks nearly perfect in normal viewing.
If the light is reflecting off the surface, I can see some of the un-even
reflectiveness in the deepest blacks caused by the very high loads, but it's
not apparent in normal viewing.  In normal viewing the blacks look good.
The test print is totally flat, with no waviness from the high black ink
loads.  I don't use cold press, but it might achieve the same dmax while
hiding the uneven reflections of the deepest blacks.  One thing I did notice
is that the paper takes a long time to dry compared to our usual coated
matte papers.
I think this could be a serious contender for some who like to identify
their photos with "fine art."  The paper color matches the matte board I use
almost perfectly.  While most who buy my photos are clueless about the paper
and ink issues, I think in some situations this paper option could have
appeal.  I'm definitely intrigued by the possibilities here.
2007-05-16 by Richard Smallfield
Ages ago, I had relative success with the uncoated 'Fabriano Artistico Rough' (better blacks than I got with the Arches Hot Press) - but you have to want texture. I've not returned to it because the coated papers have better dmax.
Richard
http://smallfield.vze.com
http://photos.smallfield.vze.com (Photos web site)
http://warkworth.vze.com/ (Warkworth photo essay)
http://picasaweb.google.com/rsmallfield/ (Recent work)
   "What is life?  It is the flash of a firefly in the night.  It is the breath
   of a buffalo in the wintertime.  It is the little shadow which runs
   across the grass and loses itself in the sunset."
   --Crowfoot, Blackfoot warior and orator, 1890 - last words.
