R2400 Graymodus with K, LK, LLK ?
2007-05-01 by jacknorthlight
Hi to all, does the R2400 use all the three graytones K,LK and LLK in the graymodus? Thanks for respones! Jack
2007-05-01 by Clayton Jones
Hello Jack, >does the R2400 use all the three graytones K,LK and LLK in >the graymodus? What is graymodus? Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2007-05-01 by Eric Chan
I assume you mean the ABW (Advanced B&W Photo) mode. If this is the case, the answer is: when color toning is disabled (e.g., Horizontal and Vertical are set to zero), the printer uses K (either MK or PK), LK, LLK, LC, LM, and Y. The inks not used are C and M. C and M may be used if color toning is enabled.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > Hello Jack, > > >does the R2400 use all the three graytones K,LK and LLK in > >the graymodus? > > What is graymodus? > > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > Hello Clayton, thanks a lot for your response - I appreciate your great work! I have a R2400 with a European printer driver which offers printing in "Grayscale Mode" like Black Only BO. Is the printer in this case using K, LK and LLK or only the black ink K? Best regards Jack
Jack, in Black Only mode, the printer is only use the K ink. This mode is only intended for printing text, not photographs.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Eric Chan" <madmanchan2000@...> wrote: > > I assume you mean the ABW (Advanced B&W Photo) mode. If this is the > case, the answer is: when color toning is disabled (e.g., Horizontal > and Vertical are set to zero), the printer uses K (either MK or PK), > LK, LLK, LC, LM, and Y. The inks not used are C and M. C and M may be > used if color toning is enabled. > Hi Eric, thank you for response! My experience is that the ABW mode in every case produces results with color toning. To avoid this I printed with my European driver setting "GraySteps". The results are pretty good and really neutral without any tone or hue! Is in this case the printer using K, LK and LLK in the way of BO with three Blacks? Or does it use only Black K? Best regards Jack
2007-05-02 by CDTobie@aol.com
>> My experience is that the ABW mode in every case produces results with color toning. To avoid this I printed with my European driver setting "GraySteps". The results are pretty good and really neutral without any tone or hue! Whether the non-ABW grayscale mode is neutral or not depends on a number of factors, such as the neutrality of the media you are printing on, and the media setting used. The AWB mode attempts to neutralize the ink/media combination by using a minimum of color ink to balance the gray inks at each level on the media in question. PrintFIX PRO extended gray profiles do a similar thing by measuring results at many levels, and producing an ICC profile that neutralizes at each level by using the necessary amount of color inks; the difference being it actually measures your output at each level, so its providing a custom blend to neutralize output. C. David Tobie Product Technology Manager ColorVision, Inc. CDTobie@... www.colorvision.com ________________________________________________________________________ AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
2007-05-02 by Clayton Jones
Hello Jack, >My experience is that the ABW mode in every >case produces results with color toning. To avoid this I printed >with my European driver setting "GraySteps". The results are pretty >good and really neutral without any tone or hue! >Is in this case the printer using K, LK and LLK in the way of BO with >three Blacks? Or does it use only Black K? The 3 K's alone produce a sort of yellowish greenish turkey vomit color, so if you're getting truly nice neutral tone then I suspect there's some colors in there somewhere. Do you have a 6x or stronger loupe? With that you can see what colors are being used. It is possible with careful experimenting in ABW mode to find settings for each paper that look photographically convincing and don't look colorized. But if you're happy with the graysteps mode then just stick with that, whatever it is. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
2007-05-03 by jacknorthlight
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Clayton Jones" <cj@...> wrote: > > Hello Jack, > > >My experience is that the ABW mode in every > >case produces results with color toning. To avoid this I printed > >with my European driver setting "GraySteps". The results are pretty > >good and really neutral without any tone or hue! > >Is in this case the printer using K, LK and LLK in the way of BO with > >three Blacks? Or does it use only Black K? > > The 3 K's alone produce a sort of yellowish greenish turkey vomit > color, so if you're getting truly nice neutral tone then I suspect > there's some colors in there somewhere. Do you have a 6x or stronger > loupe? With that you can see what colors are being used. > > It is possible with careful experimenting in ABW mode to find settings > for each paper that look photographically convincing and don't look > colorized. But if you're happy with the graysteps mode then just > stick with that, whatever it is. > > Regards, > Clayton > > > Info on black and white digital printing at > http://www.cjcom.net/digiprnarts.htm > Hi to all, just now I received a statement of an Epson employee: The German printer driver for the R2400 offers printing in the "Grayscale-Mode" with the three Blacks K, LK and LLK, so its real BO with three K-Inks without tone or hue. Thanks for help, especially to Clayton for his most valuable advice in BO printing! Jack
2007-05-03 by Clayton Jones
Hello Jack, >just now I received a statement of an Epson employee: >The German printer driver for the R2400 offers printing in the >"Grayscale-Mode" with the three Blacks K, LK and LLK, >so its real BO with three K-Inks without tone or hue. I just downloaded and installed the latest European driver 6.5c dated April '07 for Vista/XP/W2K. It does indeed have a Grayscale check box and I just ran a print. Sorry to say, it is _not_ K-Only. It is a very blueish cold tone (on EEM), and under a 6x loupe I can see loads of either C or LC dots, plus a small amount of either M or LM and some Y. This is just a dumbed down arbitrary grayscale tone for (I guess) people who don't want to fiddle with ABW settings. As I said before, when you print using K-Only you get an ugly sickish yellow green tone. OF COURSE, in Epson's infinite wisdom, installing a new driver erased all my custom settings and user defined paper sizes...SIGH. You'd think Epson would be intelligent enough to know that people actually use their custom settings and store these in a separate folder so that updating a driver wouldn't erase them. But I guess that's too much to ask. To add insult to injury, it now has a very large and in-your-face bright white printing popup dialog that is obnoxious compared to the small gray discreet one in the original driver. To add Co$t to the injury and insult, the new driver triggered a full blown cleaning cycle. GRRRRRRRRR!!!!! I am now going to try and restore back to the original driver. What a royal pain. IF IT AIN'T BROKE DON'T FIX IT! Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
Here's an update: - Tried to reinstall the original driver from a download file. Seemed to work ok but printer still uses new driver. Tried turning printer off/on, no luck. - tried again with a reboot, same result. - uninstalled printer, then tried to reinstall printer from scratch using original install disk. Got part way through and failed - can't find some DLL. Now am really stuck. Can't go back or forward. How nice. - Used System Restore, selecting last restore point, rebooted, printer still sees new driver. Darn! Worse than a worm. - Did system restore again with last night's restore point, rebooted, this time the 2400 is there and properties shows the original driver. However, any program trying to print to the 2400 causes a runtime error. - uninstalled the 2400 again, tried to install again from original disk. This time it worked. Printer shows original driver and can make test print. Bet you think this drama is finally over, huh...guess again. - Now I open photoshop CS and it says I need to reactivate because the system has changed. Clicked the reactivate button, it goes on line and gets rejected - pops up window showing serial# and activation # and says I need to activate by phone. Called in and got the auto system that says to enter the numbers. Acceps serial#, rejects the activation # (twice - says it has too many digits). Finally after the usual rigamarole I get a real person on the phone who sounds like he's in India and I can hardly understand him. After my explanation he puts me on hold for awhile. then comes back and asks for the two numbers, then on hold again. then he says it was rejected because it has already been activated twice, and wants an explanation. I explain that a few months ago I installed a new MB and CPU, which required an activation. He accepts that and gives me an authorization code, it works. - Finally. am back in business with original driver and everything seems to be ok. Total time for this fun little exercise is about 3.5 hours. Half a day wasted. What joy. - Moral of the story - don't update the driver unless you are _REALLY_ sure you want it. Regards, Clayton Info on black and white digital printing at http://www.cjcom.net/digiprnarts.htm
